iLogic: detect if sheet metal part can produce a flat pattern
diegojacobs
diegojacobs
I'm making an ilogic rule to write the flat pattern extents to the properties.
if a flat pattern doesn't exist, the code creates a flat pattern.
If the part doesn't contain a face or other sheet metal feature the code produces an error.
So I would like to create an If statement that finds out if there is anything to flat pattern in the part at all before I execute the rest of the code.
Any suggestions, or maybe a different approach to achieve this result?
bhavik4244
