iLogic detect if adaptive assembly is hose&pipe or harness
danmachen
danmachen
Hi guys,
I'm writing an iLogic tool to help CAD users identify if there are any adaptive assemblies in their current assembly.
I have the script to cycle through all the active components in the assembly, I just don't know if there is anything in the object model to detect if they are harness or tube&pipe runs.
The idea is to alert the user of an adaptive assembly unless it is a harness or tube&pipe model. In which case, no alert is made.
Any help appreicated.
Dan
Dan Machen
Ideas that need support:
Circular / Rectangular Point Matrix
Allow Axis & Plane Selection on Rectangular / Circular pattern
Graphical iLogic Programming
bradeneuropeArthur
 Sub SuppressAdaptivity(oInvApp As Inventor.Application)
        Dim oAsmDoc As AssemblyDocument
        oAsmDoc = oInvApp.ActiveDocument
        Dim occ As ComponentOccurrence
        Dim occs As ComponentOccurrences
        occs = oAsmDoc.ComponentDefinition.Occurrences
        For Each occ In occs
            If occ.Adaptive = True Then
                Dim fi As New System.IO.FileInfo(occ.ReferencedDocumentDescriptor.FullDocumentName)
                If Not fi.IsReadOnly = True Then
                    occ.Adaptive = False
                Else
                    MsgBox(occ.ReferencedDocumentDescriptor.FullDocumentName & " Is Read-only")
        Next
    End Sub
and this:
https://forums.autodesk.com/t5/inventor-customization/get-document-subtype-framegenerator-contentcen...
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
 Sub SuppressAdaptivity()
        Set oAsmDoc = ThisApplication.ActiveDocument
        Set occs = oAsmDoc.ComponentDefinition.Occurrences
                'Dim fi As New System.IO.FileInfo(occ.ReferencedDocumentDescriptor.FullDocumentName)
Dim a As Document
Set a = occ.ReferencedDocumentDescriptor.ReferencedDocument
If a.DocumentInterests.HasInterest("Piping Runs Environment") = True Or a.DocumentInterests.HasInterest("HarnessPart") = True Then
                    MsgBox (occ.ReferencedDocumentDescriptor.FullDocumentName & " = adaptive")
        Next
    End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
