The Coding for the drawings is as follows, though I do tweak it for each drawing if I need to.
trigger = iTrigger0
iTrigger0 = iLogicVb.RunRule("Rule0")
'VIEW 1 - SETTINGS
ActiveSheet.View("VIEW1").Scale = (1) 'This sets the scale size
ActiveSheet.View("VIEW1").SetSpacingToCorner(0.0, 140.0, SheetCorner.BottomLeft) 'This sets the position of the view, referenced to a corner
'If (ActiveSheet.Name <> "Sheet:1") Then Return 'This checks to make sure that you are on sheet 1, if so it carries on
Dim viewL = ActiveSheet.View("VIEW1") 'This looks like it sets the value of VIEW1 to viewL
Dim view = viewL.View 'then this sets the value in viewL to that of view (please note the capitalisms)
If (view.BreakOperations.Count > 0) Then 'This checks if there is a break view already
Try
Catch
End Try
Try
view.BreakOperations(1).Delete 'if there is then this line deletes it first
Catch
End Try
End If
modelLength = GoExcel.CellValue("D:\Training Vault\Drawings\Z Conveyor MASTER\0\Conveyor MASTER Control DATA.xlsx", "Inventor", "B18")
If (modelLength > 1194.0) Then 'This gets a value from Excel and checks it against a set value
Dim breakWidth As Double = (modelLength - 1090.0) 'This sets the break size
Dim xMid As Double = GoExcel.CellValue("D:\Training Vault\Drawings\Z Conveyor MASTER\0\Conveyor MASTER Control DATA.xlsx", "Inventor", "F18") 'This sets the X dimension for the new break to be
Dim startPt_preSplit = ThisApplication.TransientGeometry.CreatePoint2d((xMid - breakWidth / 4) * 0.1, 0) 'This sets the start point of the break
Dim endPt_preSplit = ThisApplication.TransientGeometry.CreatePoint2d((xMid + breakWidth / 4) * 0.1, 0) 'This sets the end point of the break
view.BreakOperations.Add(BreakOrientationEnum.kHorizontalBreakOrientation, startPt_preSplit, endPt_preSplit) 'This puts in a Horizontal break
Dim oxMid As Double = GoExcel.CellValue("D:\Training Vault\Drawings\Z Conveyor MASTER\0\Conveyor MASTER Control DATA.xlsx", "Inventor", "H18") 'This sets the X dimension for the new break to be
Dim startPt_postSplit = ThisApplication.TransientGeometry.CreatePoint2d((oxMid - breakWidth / 4) * 0.1, 0) 'This sets the start point of the break
Dim endPt_postSplit = ThisApplication.TransientGeometry.CreatePoint2d((oxMid + breakWidth / 4) * 0.1, 0) 'This sets the end point of the break
view.BreakOperations.Add(BreakOrientationEnum.kHorizontalBreakOrientation, startPt_postSplit, endPt_postSplit) 'This puts in a Horizontal break
End If
ActiveSheet.View("VIEW1").Scale = (350 / ActiveSheet.View("VIEW1").Width) 'This sets the scale size to my 450mm I require divided by the value of View Width
ActiveSheet.View("VIEW1").SetSpacingToCorner(85, 140, SheetCorner.BottomLeft) 'This sets the position of the view, referenced to a corner
'VIEW 2 - SETTINGS
ActiveSheet.View("VIEW2").SpacingBetween("VIEW1") = 110 'This sets view2 away from the fixed view1 by 130mm
'VIEW 3 - SETTINGS
ActiveSheet.View("VIEW3").SpacingBetween("VIEW1") = 150 'This sets view2 away from the fixed view1 by 150mm
'VIEW 4 - SETTINGS
ActiveSheet.View("VIEW4").Scale = (1) 'This sets the scale size
ActiveSheet.View("VIEW4").Scale = (280 / ActiveSheet.View("VIEW4").Width) 'This sets the scale size to my 210mm I require divided by the value of View Width
ActiveSheet.View("VIEW4").SetSpacingToCorner(10, 10, SheetCorner.TopRight) 'This sets the position of the view, referenced to a corner
This coding is for the following drawing. Though I have not run it yet
K.I.S.S. (keep it simple stupid)
Life doesn't have to be complicated.
Designs don't have to be complicated.
GOD Bless you.
