iLogic Delete Files containing string Value
jam_bhatti
Message 1 of 12
jam_bhatti
I am trying to delete files containing similar words in files. in my case NN as perameter value and exist in all files as mentioned in below list.
"Nozzle-01_" & NN & ".iam"
"Nozzle Neck-01-01_" & NN & ".ipt"
"NozzleRepad-01-01_" & NN & ".ipt"
"Flange-01-01_" & NN & ".ipt"
"Blind-01-01_" & NN & ".ipt"
"Gasket-01-01_" & NN & ".ipt"
found some way and applied but un-successful.
if someone help me it will be highly appreciated.
Thanks in advance
SyntaxEditor Code Snippet
Dim iPath As String = ThisDoc.Path & "\"
Dim ContainingFileName As String = NN
If IO.File.Exists(iPath.Contains(ContainingFileName)) Then
    IO.File.Delete(ContainingFileName)
Replies (11)
Message 2 of 12
MechMachineMan
Google: Msdn + vb.net + delete files.
Good luck.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 3 of 12
jam_bhatti
HI,
@MechMachineMan
Thanks for your reply i think every one first putting query on google to find solution and then post to the forum.
and i am still did't find solutiion from google (MSDN) or may be unable to compile them with my porblem. i hope you will help with some code snippets.
Message 4 of 12
MechMachineMan
1) ThisDoc.Path only gets you the path of the folder the file is in, not the folder. Use
ThisApplication.ActiveDocument.FullFileName instead.
If you get errors, plz post screenshots of them so that we can help debug without having to recreate the program/documents
Justin K
Message 5 of 12
jam_bhatti
HI,
Nothing happened, close rule without any error. file still exist in the folder.Smiley Sad
Dim iPath As String = ThisApplication.ActiveDocument.FullFileName
If System.IO.File.Exists(iPath.Contains(ContainingFileName)) Then
    System.IO.File.Delete(ContainingFileName)
Message 6 of 12
MechMachineMan
How you currently have it written, it will only delete the file you have open in inventor if it's name has NN. Seeing as the file is in use, it is probably not allowing you to delete it.
Justin K
Message 7 of 12
jam_bhatti
as my first post the folder exist many files containg file name "NN" which i define when created the parts or assemblies. the same way i want to delete them which file names are containing or having names with "NN".
File name are show below
so please correct me to meet my requirements.
Message 8 of 12
MechMachineMan
Dim oFile As String
Dim oFiles As String()
oFiles = System.IO.Directory.GetFiles(oFolder)
For Each oFile In oFiles
Next
Justin K
Message 9 of 12
GeorgK
Maybe like this:
For Each foundFile As String In My.Computer.FileSystem.GetFiles(
    My.Computer.FileSystem.SpecialDirectories.MyDocuments,
    Microsoft.VisualBasic.FileIO.SearchOption.SearchAllSubDirectories, "*.ipt")
    Listbox1.Items.Add(foundFile)
Next
Message 10 of 12
MechMachineMan
You could also try something like:
https://msdn.microsoft.com/en-us/library/ms143316(v=vs.110).aspx
System.IO.Directory.GetFiles ( _
	path As String, _
	searchPattern As String, _
	searchOption As SearchOption _
) As String()
Parameters path Type: System.String
The relative or absolute path to the directory to search. This string is not case-sensitive.
searchPattern Type: System.String
The search string to match against the names of files in path. This parameter can contain a combination of valid literal path and wildcard (* and ?) characters (see Remarks), but doesn't support regular expressions.
searchOption Type: System.IO.SearchOption
One of the enumeration values that specifies whether the search operation should include all subdirectories or only the current directory.
Justin K
Message 11 of 12
xiaodong_liang
Autodesk Support
Autodesk Support
Hi jam_bhatti,
It looks to me some of the replies from the gurus have helped this question,
but it seems you assigned NN to ContainingFileName without the quotation mark? I think it should be:
Dim ContainingFileName As String = "NN"
Are you still having the problem? If no, could you mark the one who helped you as a solution? thank you.
Message 12 of 12
jam_bhatti
Thanks to all
finally i get the solution as quoted
'Delete Files from folder containing NN
Dim path As String = ThisDoc.Path & "\"
For Each foundFile As String In My.Computer.FileSystem.GetFiles(path,
Microsoft.VisualBasic.FileIO.SearchOption.SearchAllSubDirectories, "*" & NN & ".*")
My.Computer.FileSystem.DeleteFile(foundFile)
Next
