iLogic Create Plane
iLogic Create Plane
kresh.bell
iLogic Create Plane
kresh.bell
Does anyone have an idea how to make iLogic who will do the following?
1) in the assembly environment, select parts that I want ...
2) On all selected parts, sfter runing iLogic, iLogic create 3 planes that pass through the center of each dimension (as shown in the figure)
MechMachineMan
Wouldn't it be much easier to just put your assemblies together with that in mind in the first place?
I guess you could always take a range box if the object isn't skewed and place planes and the center of that, but there are a lot of difficulties involved in making the planes do as you wish if each "selection" doesn't cover the entire face.
For now using the Add WorkPlane by Midplane or revising you modelling techinques are probably the best bet.
The only way I think it would make sense to have code for this is if you have a TON of assembly models that were done poorly in the first place (ie; > 50) and that need this as a retroactive fix for some reason.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
