iLogic Create Named Geometry in Assemblies
josiah_pekary
josiah_pekary
Is there a way to name geometry on an assembly level. I know how to create constraints and drawing dimensions using "Named Geometry" for parts. However, I would like to do the same for assemblies and subassemblies. If I click on a face or edge in an assembly, I cannot give it a name the same way I can at the part level. Is there a way to do this or is it not a feature yet?
JaneFan
Hi @josiah_pekary ,
Naming geometry functionality is only supported in part environment. If you are operating in assembly environment, please double click the relative part browser to navigate to part in-place-edit environment to set geometry name.
Jane Fan
Inventor/Fusion QA Engineer
