iLogic count all opened drawing
I need to count how much drawing (IDW) are opened in Inventor.
I tried with this, but doesn't work...
Dim a As Integer = 0
a = ThisApplication.DrawingDocument.count
What do I do wrong ?
frederic.vandenplas
Dim i, iDrawCounter As Integer
For i = 1 To ThisApplication.Documents.VisibleDocuments.Count
If ThisApplication.Documents.VisibleDocuments.Item(i).DocumentType = kDrawingDocumentObject Then
    iDrawCounter = iDrawCounter + 1
Next i
MessageBox.Show(iDrawCounter &" drawing(s) is/are open", "My iLogic Dialog", MessageBoxButtons.OK, MessageBoxIcon.Asterisk, MessageBoxDefaultButton.Button1)
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
No, I'm looking for a simple code in one line, like "ThisApplication.DrawingDocuments.count".
Actually I use this :
Dim nbrIDW As Integer = 0
For Each doc In ThisApplication.Documents
	If doc.DocumentType = kDrawingDocumentObject Then nbrIDW = nbrIDW + 1
Next
How can I use it with .count method ?
frederic.vandenplas
Good luck then! Smiley Happy
MechMachineMan
When newbs both ask for help and tell you how to do things at the same time.........
Just make it a sub/function to call the counter in one line then.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
