ilogic - Copy iproperties from assembly to various parts
Message 1 of 31
Hi.
I have an issue and couldn't find an exact answear.
I want to copy iproperty value form assembly to all sub-components (assemblies, parts and parts of asemblies).
Amount of this sub-components is various.
Names of this sub-components are various.
There can be many levels of assemblies.
I want this ilogic rule to be run from main assembly.
This iproperty might be a custom property (let's name it NR).
Could You help please?
Replies (30)
Message 21 of 31
If you keep your purchased items in your Library (defined in Project) then this code will do exactly what you want.
Or maybe you would like an another approach?
Message 22 of 31
That will do what you want if you keep your purchased items in Library (defined in Porject).
Or maybe you want an another approach?
Please try my code and tell if it works.
(Sorry for two answers in a row - dodn't see that new page was created)
Message 23 of 31
tecnico
First error(Ita):    iProperties: impossibile trovare la proprietà denominata "NR".
Message 24 of 31
I added two codes.
First one is for you - it will populate "Project" property from your Input to all subcomponents.
Second is refered to custom properties - i added it because it was primary objective of this topic.
Try first code.
Message 25 of 31
nivyus
体积改成密度无法实现,是哪里不对吗。
Message 26 of 31
tecnico
Unfortunately I am not yet experienced enough to distinguish a first part from a second, could you kindly send me the complete rule that can work without needing to modify it? thanks a lot
Message 27 of 31
I did it already.
Did you try this code?
iProperties.Value("Project", "Project") = InputBox("Riferimento al progetto", "Progetto", "Default Entry")
	Dim oAssyDoc As AssemblyDocument = ThisApplication.ActiveDocument
    Dim AllRefDocs As DocumentsEnumerator = oAssyDoc.AllReferencedDocuments
    Dim oDoc As Inventor.Document = Nothing
	Dim oProjectMgr As DesignProjectManager = ThisApplication.DesignProjectManager
	Dim CCPath As String = oProjectMgr.ActiveDesignProject.ContentCenterPath
	Dim i As Integer
	Dim isCC As Boolean = False
	Dim isLibrary As Boolean = False
        Dim strNR as string = iProperties.Value("Project", "Project")
    For Each oDoc In AllRefDocs
		For i = 1 To oProjectMgr.ActiveDesignProject.LibraryPaths.Count
			If oDoc.FullFileName.Contains(oProjectMgr.ActiveDesignProject.LibraryPaths.Item(i).Path) = True Then
				isLibrary = True
				Exit For
		Next
		If oDoc.FullFileName.Contains(CCPath) = True Then
			isCC = True
		If isCC = False And isLibrary = False Then
	        Dim invDesignInfo As PropertySet
	        invDesignInfo = oDoc.PropertySets.Item("Design Tracking Properties")
	        Dim invProjectProperty As [Property]
	        invProjectProperty = invDesignInfo.Item("Project")
	        invProjectProperty.Value = strNR
    	isCC = False
		isLibrary = False
    Next
Message 28 of 31
tecnico
The rule works great !!!!
only now I would like to know if it is possible to do it also for the "Title" parameter and if it is possible to leave out the components that are purchased in the bill, and obviously all the sub-parts present in these. Anyway thank you very much already so it is a huge step forward
Message 29 of 31
Try if it works
iProperties.Value("Summary", "Title") = InputBox("Riferimento al titolo", "Titolo", "Default Entry")
	Dim i As Integer
	Dim isPurchased As Boolean = False
        Dim strNR As String = iProperties.Value("Project", "Project")
		Dim strTit As String = iProperties.Value("Summary", "Title")
				isLibrary = True
				Exit For
		Next
			isCC = True
		If oDoc.ComponentDefinition.BomStructure = 51973 Then
			isPurchased = True
		If isCC = False And isLibrary = False And isPurchased = False Then
			Dim invSummaryInfo As PropertySet
	        invSummaryInfo = oDoc.PropertySets.Item("Inventor Summary Information")
			Dim invTitleProperty As [Property]
	        invTitleProperty = invSummaryInfo.Item("Title")
			invTitleProperty.Value = strTit
    	isCC = False
		isLibrary = False
		isPurchased = False
    Next
Message 30 of 31
tecnico
PERFECT.
Message 31 of 31
I think this long topic deserves closing
