iLogic convert decimal to fraction
Happy Monday All,
   So Neil helped me to string together part descriptions in iLogic and pass them to the description field in iProperties.
Example:
iProperties.Value("Project", "Description") = Thickness & " " & Material & " x " & Width & " in. x " & Length & " in. Lg."
 My question now is can I have the values displayed in the "Description" field as fractions instead of decimal values and how would my code read. I found the "FormatAsFraction" function under the "String" snippets but can't seem to get the syntax right. Thanks to all for you patience and assistance. Have a great week.
Frank
Curtis_Waguespack
Hi frank,
Try something like this:
'variables/values that would come from the model
Material = "Steel"
Thickness = .125
Width = 1.5
Length = 6.25
'convert values to fraction
oT = FormatAsFraction(Thickness)
oW = FormatAsFraction(Width)
oL = FormatAsFraction(Length)
'set description
iProperties.Value("Project", "Description") = _
oT & " " & Material & " x " & oW & " in. x " & oL & " in. Lg."
'display to user
MessageBox.Show("Description: " & vbLf & _
iProperties.Value("Project", "Description"), "iLogic")
I hope this helps.
Curtis
Curtis_Waguespack
Or something like this if you need to control the precision:
Material = "Steel"
Thickness = 0.103587
Width = 1.5625
Length = 6.3987
oT = RoundToFraction(Thickness, 1/8, RoundingMethod.RoundUp)
oW = RoundToFraction(Width, 1/16, RoundingMethod.RoundUp)
oL = RoundToFraction(Length, 1/32, RoundingMethod.RoundUp)
'set description
'display to user
Curtis,
Second example worked like a charm once I got the syntax correct. I really appreciate the assistance. I've watched all the tutorial videos I could on iLogic and couldn't put it together until I saw it applied to what I was doing. All of the stuff in the videos was all theoretical and kind of abstract to me. I think for myself, it all started to come together when I saw it applied to what I'm doing. Thanks again for your help.
Frank
How do you do all this in VBA since if you use RoundToFraction(Variable,1/64, RoundingMethod.Round) it throws an error that the Function isn't defined.
Any insight anyone?
You stick to VB.net or iLogic or create your own function in VBA?
https://stackoverflow.com/questions/706468/how-can-i-convert-a-decimal-to-a-fraction
MechMachineMan
The other option:
- Set your parameters up as "Exposed" and use the Custom Property Format to set the unit display as desired.
- Revise your code to look like this:
iProperties.Value("Project", "Description") = "=" & "<Thickness> <Material> x <Width> in. x <Length> Lg."
This utilizes the iProperty expressions (which will show up beside the iProperty as "fx")
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
