iLogic Component.Replace only works with Vaulted parts, not assemblies.
In an iLogic rule I do some file replacement like this:
 Component.Replace("MyPart", "1.ipt", True)
Component.Replace("MyAssembly","2.iam", True)
1.ipt and 2.iam are Vaulted files. If they are missing in my working folder iLogic knows to look in the Vault before the rule fails. This is a nice feature - but for the assembly, 2.iam, it will only get the assembly itself from Vault. Not any parts referenced by the assembly. So the rule fails anyway.
Has anyone found a way around this problem?
DeerSpotter
I know i know, last year...
But i got here this year regardless.
You said Vault will look for the missing parts in assembly? Then thats what the issue is. Its not the Component replace rule failing. It's your .iam
What you need to do is Ilogic Update it at the end that will refresh all .ipt's and .iam's in current .iam
Image and video hosting by TinyPic
See My LinkedIn Profile
Skadborg.NTI
2013 couldn't do it. It's fixed in 2014.
