Need help with ilogic File Save rule...
JamesNordgren
Message 1 of 9
JamesNordgren
Hello,  can someone point out why this code does not work?  Strange thing is, it seems to have worked and saved my file the first time I ran it, but then will not work again.  SaveAs file dialog opens, I hit OK to save, and nothing happens.  No error, just nothing.
Code pasted below: I copied from an included snippet, and modified it.
Dim oFileDlg As inventor.FileDialog = Nothing
InventorVb.Application.CreateFileDialog(oFileDlg)
oFileDlg.Filter = "Inventor Files (*.iam;*.ipt)|*.iam;*.ipt|All Files (*.*)|*.*"
'oFileDlg.Filter = "XML Files (*.xml)|*.xml"
oFileDlg.Filter = "Excel Files (*.xls;*.xlsx)|*.xls;*.xlsx"
oFileDlg.Filter = "Text Files (*.txt;*.csv)|*.txt;*.csv"
oFileDlg.Filter = "SAT Files (*.sat)|*.sat"
oFileDlg.Filter = "IGES Files (*.igs)|*.igs"
oFileDlg.Filter = "Step Files (*.stp)|*.stp"
oFileDlg.DialogTitle = "Select a File"
oFileDlg.InitialDirectory = "C:\Vault Workspace\Projects\DSE Jobs\" 'ThisDoc.Path
oFileDlg.FileName = "C:\Vault Workspace\Projects\DSE Jobs\" & Left(sJobNumber,3) & "\" & sJobNumber & "EXTERNAL\ASSEMBLY\" & sJobNumber & "." & PartNumbers & ".ipt" 'ThisDoc.Path
oFileDlg.CancelError = True
On Error Resume Next
oFileDlg.ShowSave()
'If Err.Number <> 0 Then
MessageBox.Show("File not SAVED.", "Dialog Cancellation")
ElseIf oFileDlg.FileName <> "" Then
selectedfile = oFileDlg.FileName
MessageBox.Show("File " & selectedfile & " was selected.", "Dialog Selection Made")
Replies (8)
Message 2 of 9
Curtis_Waguespack
Hi JNORDGREN,
I think this line is generating an error:
And the On Error Resume Next is hiding it.
Comment out On Error Resume Next and I think you'll see it.
I hope this helps.
Curtis
Message 3 of 9
JamesNordgren
Thank you Curtis,
However, it still doesnt work after commenting out the 'ON ERROR RESUME'.
I have attached the rule in a file... any other ideas why it creates the dialog but does not save the file?
Message 4 of 9
Curtis_Waguespack
Hi JNORDGREN,
I'm not sure you need the dialog box for what you're doing.
If you are just trying to save the file as a new file you might not need to create a dialog box, instead you can use something like this:
sName = iProperties.Value("Project", "Part Number") & "_Test.ipt"
sPath = "C:\Temp\"
'Save File As
'True saves off a copy of this file as the new name
'False saves this file as the new name
ThisDoc.Document.SaveAs(sPath & sName , False)
If you want the dialog box so that the user can browse for the location, you can use something like the example at this link:
http://inventortrenches.blogspot.com/2012/10/ilogic-adding-save-as-dialog-box.html
I hope this helps.
Curtis
Message 5 of 9
JamesNordgren
Thanks!!  The link to your blog had exactly what I was missing.
Message 6 of 9
Hi Curtis,
Sorry to HiJack this link
I too am finding your code helpful, but is there a way to define the 'WorkSpacePath' ?
I would like to set it to a particualr folder within the workspace area.
Regards
Gareth
Message 7 of 9
The following code was written by me for the sole purpose saving an Inventor file so that the file Title begins the saved file name along with the Part Number something like:
Framus (123456).i?? where
Title = Framus and Part Number = 123456
The code is also attempting to see if either field is blank.  If either Title or Part Number are blank, the code needs to allow the user to fill in the missing information.  I wish to use this code with any of the Inventor file types a user could create.  The current code doesn't work at the moment.
'Collect information to complete file naming convention when saving files
'Define the active document
oDoc = ThisDoc.Document
'Look-up values for both the Title and Partnumber
oTitle = iProperties.Value("Summary", "Title")
oPartNumber = iProperties.Value("Project", "Part Number")
'Test the Title to see if it's blank
If oTitle = "" Then
i = MessageBox.Show("Title info must be filled out before saving file!", "Title Information is missing", MessageBoxButtons.OK, MessageBoxIcon.Asterisk, MessageBoxDefaultButton.Button1)
If oPartNumber = "" Then
i = MessageBox.Show("Part Number must be filled out before saving file!", "Part Number is missing", MessageBoxButtons.OK, MessageBoxIcon.Asterisk, MessageBoxDefaultButton.Button1)
'Show Form to allow entry of Title and PartNumber Information
iLogicForm.Show("Title Information", FormMode.Modal)
'Set value of currrent file name
oNewFileName =  iProperties.Value("Summary", "Title") & " " & "(" & iProperties.Value("Project", "Part Number") & ")"
oDoc.SaveAs(oNewFileName, False) 'True = Save As Copy & False = Save As
It's my hope to write this rule as an External Rule so that it can be run at any time on any Inventor file.
Any help would be appreciated!
Message 8 of 9
Curtis_Waguespack
Hi  JimStrenk.
This should work for you:
'check for blank iProperty
If iProperties.Value("Summary", "Title") = "" Then
'prompt user for info if iProperty is blank
oTitle = InputBox("Title info must be filled out before saving file!", _
"iLogic - Title", iProperties.Value("Summary", "Title"))
    'check for empty input
    'in case the user cancels out of the input box
    If oTitle = "" Then
    Return 'end rule
    Else
    End if
'write user input to the iProperty
iProperties.Value("Summary", "Title") = oTitle
If iProperties.Value("Project", "Part Number") = "" Then
oPartNumber = InputBox("Part Number must be filled out before saving file!", _
"iLogic - Part Number", iProperties.Value("Project", "Part Number"))
    'in caset he user cancels out of the input box
    Return 'end rule
    Else
    End if
iProperties.Value("Project", "Part Number") = oPartNumber
oNewFileName =  iProperties.Value("Summary", "Title") _
'Save the file
'False = Save As
 I hope this helps.
Curtis
Message 9 of 9
Curtis, close, very close.  The code is not working however.  Your code did allow me to input the Title and Part Number iProperties.  Once entered, the code fails.  These are the error messages that I get when running your code:
ERROR MESSAGE:
Error in rule: iLogic File Namer, in document: Part1
The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
And ...
MORE INFO
System.ArgumentException: The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
at Microsoft.VisualBasic.CompilerServices.LateBinding.InternalLateCall(Object o, Type objType, String name, Object[] args, String[] paramnames, Boolean[] CopyBack, Boolean IgnoreReturn)
at LmiRuleScript.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
My 'design intent' is to run this rule externally, be independent of Inventor file type, and also independent of whether Title and Part Number are filled or blank.  Code to work on currently opened file, and save the current file, if possible.
Here's the code as entered in the iLogic Editor:
'in case the user cancels out of the Input box
If oTitle = "" Then
Return 'end rule
Else
Return 'end rule
Else
'Save the file 'True = Save As Copy 'False = Save As
'End of iLogic File Namer.iLogicVB Code
System Specs.: Windows 7 Pro, PDSU 2014, Vault Basic 2014 Client, Vault Basic 2014Server
BTW, I've enjoyed purchasing and reading all of your Master Autodesk Inventor Series.  I'm sorry to report I was late in purchasing the 2014 Edition (July 2, 2013).  I enjoyed the reading more than the purchasing.  Tee hee!
How did you and the other major iLogic contributors learn this stuff?  While your books do a good job of discussing the basics if iLogic, are there other sources you or other might recommend regarding writing iLogic code?  If you had the time, I'd ask that you author "The iLogic Bible".
I highly recommend your web site for more information about using iLogic.
Again, thank you for your assistance in helping me with the iLogic code.  It is appreciated!  Smiley Very Happy
