iLogic code to create a User Parameter
Message 1 of 36
I want to use iLogic to create User Parameters with Multi-Value lists filled with info from an excel spreadsheet. What is the code to create a new User Parameter? I can't seem to find it in the help wiki.
Thanks!
Replies (35)
Message 21 of 36
WCrihfield
Hi @Biju.Veedu.  I don't know why I didn't think about this earlier, but the FlatPattern object kind of acts like a ComponentDefinition object, because it is derived from it, so it has it's own separate set of parameters and user parameters.  It's user parameters aren't even available to the main parent component definition, because they are at a deeper level.  Here is an iLogic rule I threw together to help you write a series of entries into the flat pattern's own user parameters.  I included several lines of comments to help guide you through what's going on.  You will need to manually edit the parameter specs to the way you want them, after determining that the code works.  I just specified 4 different types of user parameters for a somewhat dynamic test (simple numeric, equation, text, & boolean).  Also, if you're not already aware, any plain numbers typed in iLogic, that represent measurements, will be understood as 'database' units (cm for length, radians for angle, etc), so you may have to either add them as an Expression, or include some math to convert its value to suit your needs.
Here's the rule:
iLogicVb.UpdateWhenDone = True
Parameter.UpdateAfterChange = True
MultiValue.UpdateAfterChange = True
Dim oPDoc As PartDocument = ThisDoc.Document
'only work with a Sheet Metal part
If Not TypeOf oPDoc.ComponentDefinition Is SheetMetalComponentDefinition Then Exit Sub
Dim oSMDef As SheetMetalComponentDefinition = oPDoc.ComponentDefinition
If Not oSMDef.HasFlatPattern Then Exit Sub
Dim oFP As FlatPattern = oSMDef.FlatPattern
Dim oUParams As UserParameters = oFP.Parameters.UserParameters
Dim oUParam As UserParameter
'create a List of Arrays of Object
'of Object Type, because the Array will include numbers, strings (text), boolean, and Enum Types
Dim oToBeCreated As New List(Of Object())
'in each Array we add to the main list, we will be entering the following items, in order
'(0) = specify if the value (below) should be understood as a plain value, or as an expression (involves an equation)
'(1) = the parameter's name
'(2) = the parameter's value or equation (if it's an equation, "enclose it within quotes")
'(3) = specify the units of the parameter
oToBeCreated.Add({"Expression", "Param_1", 25.75 in, UnitsTypeEnum.kInchLengthUnits})
oToBeCreated.Add({"Expression", "Equation_1", "Param_1 + 4.25 in", UnitsTypeEnum.kInchLengthUnits})
oToBeCreated.Add({"Value", "Text_1", "A Text Value", UnitsTypeEnum.kTextUnits})
oToBeCreated.Add({"Value", "Boolean_1", True, UnitsTypeEnum.kBooleanUnits})
'now try to either update or create these user parameters
'remember, an Array is zero (0) based, not 1 pased, so its first item is zero (0)
For Each oSpecs As Object() In oToBeCreated
	Try
		'try to find and update the value of the existing user parameter
		If oSpecs(0) = "Value" Then
			oUParams.Item(oSpecs(1)).Value = oSpecs(2)
		ElseIf oSpecs(0) = "Expression" Then
			oUParams.Item(oSpecs(1)).Expression = oSpecs(2)
	Catch
		'that failed, so it doesn't exist yet, so create it
			oUParam = oUParams.AddByValue(oSpecs(1), oSpecs(2), oSpecs(3))
			oUParam = oUParams.AddByExpression(oSpecs(1), oSpecs(2), oSpecs(3))
	End Try
Next
RuleParametersOutput
oPDoc.Update2(True) ' True = accept any errors and continue
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS 💡or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
Message 22 of 36
c.neutschK4ZB6
Is it also possible to use that code with a little modification in drawings?
I want to create a parameter that is filled with values by an excel, without manually creating that parameter in the drawing template. E.g. to create a list of coatings as multi value parameter list.
Message 23 of 36
theo.bot
For drawings there is no component definition. Parameters are directly available from the document definition.
here is a quick sample to create a parameter in a drawing. of course it's better to add some checks etc. like the previous codes in this post.
Dim oDoc As DrawingDocument
oDoc = ThisDoc.Document
'add number
oDoc.Parameters.UserParameters.AddByExpression("Number", "10", UnitsTypeEnum.kMillimeterLengthUnits)
'add Boolean
oDoc.Parameters.UserParameters.AddByValue("Istrue", True, UnitsTypeEnum.kBooleanUnits)
'add text
oDoc.Parameters.UserParameters.AddByValue("Text", "New", UnitsTypeEnum.kTextUnits)
Message 24 of 36
WCrihfield
Hi @c.neutschK4ZB6.  There is a one line iLogic snippet within the 'System' side of the Snippets in a folder called "Excel Data Links" which is labeled "MultiValue list from Excel".  You might be able to use that to get a list of values from an Excel sheet to a multi-value user parameter in your drawing.
Here is what that snippet's code looks like:
MultiValue.List("d0") = GoExcel.CellValues("filename.xls", "Sheet1", "A2", "A10")
You would have to change the name of the Parameter being specified, and that parameter would have to already exist.  Then you would have to fill in the real name of your Excel file (full path may be needed), sheet name, and cell addresses.
And if the parameter doesn't already exist, you could add a line of code above that to create the needed parameter like this.
ThisDrawing.Document.Parameters.UserParameters.AddByValue("ExcelValues", "", "Text")
MultiValue.List("ExcelValues") = GoExcel.CellValues("C:\Temp\Parameter Values.xlsx", "Sheet1", "A2", "A10")
Notice that the parameter is created as a Text type parameter, because I am expecting text type values.  If you are expecting different data type, such as numbers, you would need to change the value and units being specified at the end of the parameter creation line.  There are lots of ways of doing that, but that's about the quickest & simplest.
Wesley Crihfield
Message 25 of 36
urban.ostirZ44XW
Hello, is it possible that we have a code like one above that work just in the assembly? So when I would start a code I would like to sum up the area of all the components in the assembly and then multiplied it by the number 0.5 and then wrote the resulting number in the table of parameters. Does someone have an idea how to do it?
Message 26 of 36
WCrihfield
Hi @urban.ostirZ44XW.  If I am fully understanding your request then I believe I have an iLogic rule that should be able to do a task like that for you.  I also put a few messages in the code for feedback, but commented them out.  Let me know if this works for you as you were wanting.  See below code:
If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
	MsgBox("An Assembly Document must be active for this rule to work. Exiting.", vbCritical, "")
	Exit Sub
Dim oADoc As AssemblyDocument = ThisDoc.Document
Dim oTotalArea As Double = oADoc.ComponentDefinition.MassProperties.Area
'MsgBox("Total Area in 'database units' = " & oTotalArea,,"")
oTotalArea = (oTotalArea * .5)
'MsgBox("Half of Total Area in 'database units' = " & oTotalArea,,"")
'<<< convert units here if needed >>>
UOM = oADoc.UnitsOfMeasure
oLengthUnitsStr = UOM.GetStringFromType(UnitsTypeEnum.kDefaultDisplayLengthUnits)
If UOM.LengthUnits <> UnitsTypeEnum.kDatabaseLengthUnits Then
	oTotalArea = UOM.ConvertUnits(oTotalArea, "cm^2", oLengthUnitsStr & "^2")
'MsgBox("Half of Total Area in 'document units' = " & oTotalArea,,"")
oUParams = oADoc.ComponentDefinition.Parameters.UserParameters
Dim oUParam As UserParameter = Nothing
For Each oUP As UserParameter In oUParams
	If oUP.Name = "HALF_TOTAL_AREA" Then
		oUParam = oUP
		oUParam.Expression = oTotalArea.ToString
Next
If IsNothing(oUParam) Then
	oUParam = oUParams.AddByExpression("HALF_TOTAL_AREA", oTotalArea.ToString, oLengthUnitsStr & "^2")
Wesley Crihfield
Message 27 of 36
pawel.swol
Hello everyone
I do not know how to write that after finding the DL, SZR, GR user parameters, it does not add the next….
below my ilogic:
Sub main
nazwa = ThisDoc.FileName(False)
iProperties.Value("custom", "kod_podst") = nazwa
iProperties.Value("custom", "segment") = nazwa
oMyParameter = ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters
oParameter=oMyParameter.AddByExpression("DL", "1", UnitsTypeEnum.kMillimeterLengthUnits)
oParameter=oMyParameter.AddByExpression("SZR", "1", UnitsTypeEnum.kMillimeterLengthUnits)
oParameter=oMyParameter.AddByExpression("GR", "1", UnitsTypeEnum.kMillimeterLengthUnits)
Logger.Info("Nie udało dodać się parametrów GR, SZR, DL")
dd= Round(Measure.ExtentsLength,2)
ss= Round(Measure.ExtentsWidth,2)
gg= Round(Measure.ExtentsHeight,2)
Dim Komunikat As String
Komunikat = "DL-" & Parameter("DL") & " SZR-" & Parameter("SZR") & " GR-" & Parameter("GR")& "."
MessageBox.Show(Komunikat, "WYMIARY")
'MessageBox.Show(Parameter("SZR"), "SZR")
'MessageBox.Show(Parameter("GR"), "GR")
If gg<ss And gg<dd Then
Parameter("GR") = gg
DL = InputRadioBox("Wybierz DL", ss, dd, booleanParam, nazwa)
If DL=False Then
Parameter("DL")=dd
Parameter("SZR")=ss
If DL=True Then
Parameter("DL")=ss
Parameter("SZR")=dd
If dd<ss And dd<gg Then
Parameter("GR") = dd
DL = InputRadioBox("Wybierz DL", ss, gg, booleanParam, nazwa)
If DL=False Then
Parameter("DL")=gg
Parameter("SZR")=ss
If DL=True Then
Parameter("DL")=ss
Parameter("SZR")=gg
If ss<gg And ss<dd Then
Parameter("GR") = ss
DL = InputRadioBox("Wybierz DL", dd, gg, booleanParam, nazwa)
If DL=False Then
Parameter("DL")=gg
Parameter("SZR")=dd
If DL=True Then
Parameter("DL")=dd
Parameter("SZR")=gg
If ss=gg Or ss=dd Or dd=gg Then
If ss<dd Or ss<gg Then
If dd>gg Then
Parameter("DL")=dd
Parameter("SZR")=gg
Else
Parameter("DL")=gg
Parameter("SZR")=dd
If gg<ss Or gg<dd Then
If dd>ss Then
Parameter("DL")=dd
Parameter("SZR")=ss
Else
Parameter("DL")=ss
Parameter("SZR")=dd
If dd<gg Or dd<ss Then
If gg>ss Then
Parameter("DL")=gg
Parameter("SZR")=ss
Else
Parameter("DL")=ss
Parameter("SZR")=gg
End Sub
thanks
Message 28 of 36
cubbanec
Observer
Observer
Hello everyone, thank you very much for these threads, they help me a lot at work and iLogic. I can't program but I manage to make small progress with code. Using the instructions from the thread, I was able to establish user parameters using a rule. But I can't figure out how to set the parameter as exported. Can you help me please? Thank you very much and greetings from the Czech Republic
oMyParameter=ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters
'Setting an userParameter as text parameter
oParameter=oMyParameter.AddByValue("Hmotnost", "", UnitsTypeEnum.kTextUnits)
oParameter = oMyParameter.AddByValue("Povrch", "", UnitsTypeEnum.kTextUnits)
Message 29 of 36
WCrihfield
Hi @cubbanec.  We were just given the ability to 'expose/export' UserParameter objects that represent 'text' or 'Boolean' units in the 2024 version o....  So, if you are using 2024, then you should be able to add another line of code after you create the parameter, just for setting its 'ExposedAsProperty' property to True.  After you set that to True, you can then access its UserParameter.CustomPropertyFormat property, and all of its added functionality, which is similar to the settings you see when you right click on a parameter in the Parameters dialog box, after checking that box, and choose Custom Property Format from the right-click menu.
Dim oUParams As UserParameters = ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters
Dim oUParam1, oUParam2 As UserParameter
oUParam1 = oUParams.AddByValue("Hmotnost", "", UnitsTypeEnum.kTextUnits)
oUParam1.ExposedAsProperty = True
oUParam2 = oUParams.AddByValue("Povrch", "", UnitsTypeEnum.kTextUnits)
oUParam2.ExposedAsProperty = True
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Wesley Crihfield
Message 30 of 36
n_lindner
Community Visitor
Community Visitor
Hello
So Far with the Examples in this Thread is Managed to Build this Following Code.
But i just dont understand how to Change the added User Parameter from beeing an "Text" Value to a Lenght (mm) Value.
I mainly Modified Line 4 from "Of String" to "Of Double" as i need the User Parameter to be an "Lenght" Type
Accordingly to this Line 21 is Modifyed by me.
Help Please
Dim sName As String = "Blechdicke_D1"
Dim oValues As New List(Of Double)
oValues.Add(0.6)
oValues.Add(0.75)
oValues.Add(0.8)
oValues.Add(1.0)
oValues.Add(1.25)
oValues.Add(1.5)
oValues.Add(2.0)
oValues.Add(3.0)
oValues.Add(4.0)
oValues.Add(5.0)
oValues.Add(8.0)
oValues.Add(10.0)
Try
    oUParam = oUParams.Item(sName)
    MultiValue.SetList(sName, oValues.ToArray)
Catch
	oUParam = oUParams.AddByValue(sName, "", UnitsTypeEnum.kMillimeterLengthUnits)
End Try
Message 31 of 36
WCrihfield
Hi @n_lindner.  In your code, Line 21 is specifying the initial value as an empty String (""), which should be a number like an unquoted 1.0, instead.  Everything else looks OK to me.
Wesley Crihfield
Message 32 of 36
kwilson_design
Hey everyone, some great stuff in this post! I'm running into a snag trying to get this to work with unitless parameters and keep getting an argument error. Will this not work with anything beyond text units?
'Setting an userparameter as unitless parameter
oParameter = oMyParameter.AddByValue("ESTIMATED_GALV_WEIGHT", "GALV_WEIGHT_MULTIPLIER * WEIGHT", UnitsTypeEnum.kUnitlessUnits)
oParameter=oMyParameter.AddByValue("GALV_WEIGHT_MULTIPLIER", "1.06", UnitsTypeEnum.kUnitlessUnits)
oParameter = oMyParameter.AddByValue("WEIGHT", "", UnitsTypeEnum.kUnitlessUnits)
Kenny
If this post solved your issue please mark "Accept as Solution". It helps everyone...really!
Message 33 of 36
WCrihfield
Hi @kwilson_design.  The initial value you are specifying is within quotation marks.  That will not work if the value is supposed to be interpreted as a Unitless value.  When the value is in quotes, it is seen as a String (text).  Remove the quotes.
Wesley Crihfield
Message 34 of 36
kwilson_design
Hey @WCrihfield I need the text to be populated and it still be unitless though since I'm telling it to multiply the Weight x 1.06. I couldn't create the Estimated Galv Weight parameter as a text parameter and it be able to detect or multiply using the * character.
Kenny
Message 35 of 36
kwilson_design
Hey @WCrihfield I figured my issue out. In case anyone is trying to something similar using unitless parameters, I just changed it to expressions instead of values. I also changed the order in which the snippet is read as that was also causing some issues. If you're using parameters of other parameters to do conversions and math, be sure you have the order right so that the "math" parameter is after the other parameters are written.  This is what worked for me....
oParameter=oMyParameter.AddByExpression("GALV_WEIGHT_MULTIPLIER", "1.06", "ul")
oParameter=oMyParameter.AddByExpression("WEIGHT", "0", "ul")
oParameter=oMyParameter.AddByExpression("ESTIMATED_GALV_WEIGHT", "GALV_WEIGHT_MULTIPLIER * WEIGHT", "ul")
Kenny
Message 36 of 36
WCrihfield
Glad to see that you figured it out.  Sorry, I did not realize you wanted to maintain the equation within the one Parameter.  For some reason I just assumed you only needed the numerical value that resulted from that equation to be recorded.  I do use the AddByExpression method the most myself, because it allows me to input values that I know will be interpreted the way I intend for them to be interpreted, instead of being automatically understood as 'database units'.  I also usually use the Parameter.Expression (instead of Parameter.Value) when setting the value of a Parameter/UserParameter/ModelParameter type API objects for the same reasons, but that only works good for setting a specific numerical value when there is not already an equation there, and that can be difficult to detect since it always contains both numerical values and text (units indicator).
Wesley Crihfield
