Get change event of attributes
jan.wagnerRB67Z
jan.wagnerRB67Z
Hello everyone,
I am currently working on an Inventor add-in which uses AttributeSets and attributes to store information for drawing automation.
Is it possible to detect a change to attributeSets or attributes using the inventor api.
With the help of @JelteDeJong I found the DocumentEvents.OnChange Event which has the ReasonsForChange as CommandTypesEnum. Does one of these Enums detect changes on Attributes?
I appreciate you help. Thank you!
Accepted solutions (3)
WCrihfield
Hi @jan.wagnerRB67Z.  Yes, that same general event (document change) can be monitored for when attributes get changed within that document.  The ReasonsForChange is usually just " kNonShapeEditCmdType", then the DisplayName = "Edit Attributes", and InternalName = "Attribute Change".  But keep in find that several things may cause that more specific event to be triggered.  Like adding or editing an internal iLogic rule, internal iLogic form, and stuff like that.  It can also be difficult to determine exactly which Object, AttributeSet, or Attribute was being changed/edited while just monitoring that event.  You may be able to monitor multiple events at the same time and cross reference data between them to get more information.  When internal iLogic rules or internal iLogic forms are created/edited, that effects document level attributes, but not all attributes are at the document level.
Wesley Crihfield
(Not an Autodesk Employee)
jan.wagnerRB67Z
Hey @WCrihfield
thank you for your detailed response. I just want to have a trigger to update a GUI which shows information about the Dimensions. I want to limit the anmount of refreshes to just the attributes, or if possible to only attributesets with my Prefix as name.
I will do some testing on my side using the helpful information you provided and maybe share my results for the next person with a similar usecase.
JelteDeJong
I just realized why you need to detect changes in the attributes. Your tool is the only tool that creates and updates those attributes. So you know when they change and you can react to it.
Jelte de Jong
Blog: hjalte.nl - github.com
