iLogic code to change iProperties on each open drawing
I frequently have to make copies of large sets of drawings and then change only a select few iproperties.  I want to automate this a little.
Dim oDoc As Document
For Each oDoc In ThisApplication.Documents.VisibleDocuments
	If oDoc.DocumentType = kDrawingDocumentObject Then
	MsgBox ("it worked once")
	iProperties.Value(ThisDrawing,"Project", "Project")="newproject"
Next oDoc
This code gives me a message box for each open drawing, but only changes the iProperties on whichever drawing is active when I run the code.
Any thoughts?
Inventor 2013
MechMachineMan
This might work:
oDoc.Activate iProperties.Value(ThisDrawing,"Project", "Project")="newproject" End If Next oDoc
or if not...
oDoc.PropertySets("Design Tracking Properties")("Project").Value = "newproject" End If Next oDoc
http://modthemachine.typepad.com/my_weblog/2010/02/accessing-iproperties.html
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
I'm sure theres a reason why
would only ever change the drawing you started with.  Even watching it cycle through all the sheets, and even though the code suggests it should be changing the iproperties, it just wasnt.
The 2nd suggestion works far better, less code, executes faster, etc.
Thanks a ton.  I'm new to programming and a minor annoyance to me with VB as I understand compared to some other lower level languages is how many different ways there are to do almost exactly the same thing.
