Ilogic code read in the Custom properties of this assambly ?
Darkforce_the_ilogic_guy
Advisor Advisor
It is possible to get a ilogic code to read an properties in the assambly  properties that the files that the Ilogic code in runner for is add in to ?
I have a code the runs when I add a part to an assambly for Centent center. What I want it to do is with the help of an properties  in the Assambly to add an new properties on the part file
If I add a file(centen Center Fil) and the Assambly already have a Properties Call Surface Sat to Colour 1 Or Colour 2
I want it to add Surface properties sat at Raw if the Part Surface Properties is Emtry
chandra.shekar.g
Autodesk Support
Autodesk Support
@Darkforce_the_ilogic_guy ,
For more understanding, can you please explain the requirement with the video record? Please make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
