Get / Set Camera view
NachoShaw
Advisor Advisor
NachoShaw
Hi
i am looking for a piece of code that ca nhelp me achieve my task which is:
add a drawing view (manually for now)
use the custom view to rotate the model to a specific view
run some code to get the camera view from the drawing view and apply that view to all other views in a drawing sheet.
I have a bunch of different parts all on one sheet like a brochure and i need all of the views to have the exact same camera view. its very difficult to do manually....
is it possible to get a camera view and apply it to another view?
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
YuhanZhang
Here is a VBA sample, you should have a drawing view placed on the first sheet in a drawing, also you should change the file path in the code for oModel:
Sub test()
    Dim oDrawing As DrawingDocument
    Set oDrawing = ThisApplication.ActiveDocument
    Dim oSheet As Sheet
    Set oSheet = oDrawing.Sheets(1)
    Dim oDrawingView As DrawingView
    Set oDrawingView = oSheet.DrawingViews(1)
    Dim oCamera As Camera
    Set oCamera = oDrawingView.Camera
    Dim oModel As Document
    Set oModel = ThisApplication.Documents.Open("C:\Temp\Part1.ipt", False)
    Dim oNewBase As DrawingView
    Set oNewBase = oSheet.DrawingViews.AddBaseView(oModel, oDrawingView.Center, 1, kArbitraryViewOrientation, kShadedDrawingViewStyle, , oCamera)
    Dim oPt As Point2d
    Dim dHeight As Double
    dHeight = oDrawingView.Center.Y / 2 + oNewBase.Center.Y / 2
    Set oPt = ThisApplication.TransientGeometry.CreatePoint2d(oDrawingView.Center.X, oDrawingView.Center.Y + dHeight)
    oNewBase.Center = oPt
End Sub
Hope this helps.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
