Place components using iLogic
andrew_canfield
andrew_canfield
After creating an assembly I'd like two sub-assemblies saving in the same location, one for the new design & one to include any reference parts required.
The two files have been created using 'save as', but placing these back into the assembly is a challenge - pasting VBA code into iLogic is returning a few errors.
The forum contains a few examples but not in iLogic ( still searching).
is there code to 'place grounded at origin'?
Regards
Andrew
JhoelForshav
Are you looking for something like this?
Dim asm As AssemblyDocument = ThisDoc.Document
Dim asmCompDef As AssemblyComponentDefinition = asm.ComponentDefinition
Dim oOcc = asmCompDef.Occurrences.Add("Path ex. C:\VaultWorkingFolder\Designs\test.iam", ThisApplication.TransientGeometry.CreateMatrix)
oOcc.Grounded = True
The occurrence gets grounded at origin because CreateMatrix creates an identity matrix 🙂
andrew_canfield
thankyou - it works 🙂
but i've managed to break it too:
(added comment in code marked '***** below)
Dim oDoc As Document
oDoc = ThisApplication.ActiveDocument
xx=ThisDoc.Path
yy=ThisDoc.FileName(False) 'without extension
nn = xx &"\"&  yy
'nn =yy
nnM = nn & "_M.iam"
nnR = nn & "_R.iam"
'MessageBox.Show(nn, "ThisDoc.Path")
MessageBox.Show(nnM, "ThisDoc.Path")
'MessageBox.Show(nnR, "ThisDoc.Path")
ThisDoc.Document.SaveAs(nnM , True)
ThisDoc.Document.SaveAs(nnR , True)
Dim oOcc = asmCompDef.Occurrences.Add(nnM, ThisApplication.TransientGeometry.CreateMatrix)
'***** everything above this line is good & one sub assembly is placed in the assembly
'***** below a 2 suffix was added because errors were cropping up & still do. trying to place the second assy (nnR) Dim asm2 As AssemblyDocument = ThisDoc.Document Dim asmCompDef2 As AssemblyComponentDefinition = asm.ComponentDefinition Dim oOcc2 = asmCompDef.Occurrences.Add(nnR, ThisApplication.TransientGeometry.CreateMatrix) oOcc2.Grounded = True
 Regards
Andrew
JhoelForshav
Did some cleaning up in the code. Try this. Works fine for me.
oDoc = ThisDoc.Document
Dim asmCompDef As AssemblyComponentDefinition = oDoc.ComponentDefinition
xx=ThisDoc.Path
nn = xx &"\"&  yy
'nn =yy
nnM = nn & "_M.iam"
nnR = nn & "_R.iam"
'''Remove old _M & _R
For Each item As ComponentOccurrence In asmCompDef.Occurrences
	If item.Name.Contains(yy) Then item.Delete
Next
'''Remove old _M & _R from inventor session, otherwise new ones can't be saved
ThisApplication.Documents.CloseAll(True)
If System.IO.File.Exists(nnM) Then System.IO.File.Delete(nnM) 'Delete old file
oDoc.SaveAs(nnM, True)
If System.IO.File.Exists(nnR) Then System.IO.File.Delete(nnR) 'Delete old file
oDoc.SaveAs(nnR, True)
Dim oIDMatrix As Matrix = ThisApplication.TransientGeometry.CreateMatrix
Dim oOcc = asmCompDef.Occurrences.Add(nnM, oIDMatrix)
Dim oOcc2 = asmCompDef.Occurrences.Add(nnR, oIDMatrix)
andrew_canfield
thankyou
