iLogic - chceck if parts in assembly has a drawing
Milan_Nosil
Message 1 of 21
Milan_Nosil
Can you help me please with creating the rule running in assembly? This rule should check that all parts and subassemblies have a drawings created. If they have a drawing, the rule creates a new user iProperty "Drawing" with a value "x" in the model (in a parts and subassemblies).
I have a rule that finds all drawings and creates pdf files (can't be publicly distributed, I would send it on request). Unfortunately, I can't edit the rule to modify models and create properties, and not to create a pdf.
Thank you very much for any advice.
MN
Replies (20)
Message 2 of 21
bradeneuropeArthur
I think this is only possible if:
  • You are using vault and whereUsed functionlity
  • Or if the files are always on a fix location. and use a routine to check these paths.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 21
fullevent
Hi @Milan_Nosil,
i think @bradeneuropeArthur is right.
I have a rule where you can select a Occurrence. The rule will check if there is a .idw or .dwg within the project.
Just copy the code in an iLogic rule. Maybe this will help you.
Sub Main
	Dim oOcc As ComponentOccurrence
	oOcc = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, "Komponente auswählen..")
    Dim oDoc As Document
    oDoc = oOcc.Parent.Parent
    ' Call the function to get the drawing.
    Dim drawingFilename As String
    drawingFilename = FindDrawingFile(oDoc)
    ' Display the result.
    If drawingFilename <> "" Then
        MsgBox ("The drawing for """ & oDoc.FullFileName & """ was found: " & vbCr & drawingFilename )
    Else
        MsgBox ("No drawing was found for """ & oDoc.FullFileName & """" )
End Sub
Private Function FindDrawingFile(PartOrAssemblyDoc As Document)
    Dim fullFilename As String
    fullFilename = PartOrAssemblyDoc.FullFileName
    Dim path As String
    path = Left$(fullFilename, InStrRev(fullFilename, "\"))
    Dim filename As String
    filename = Right$(fullFilename, Len(fullFilename) - InStrRev(fullFilename, "\"))
    filename = Left$(filename, InStrRev(filename, ".")) & "dwg"
    drawingFilename = ThisApplication.DesignProjectManager.ResolveFile(path, filename)
    If drawingFilename = "" Then
        filename = Left$(filename, InStrRev(filename, ".")) & "idw"
            FindDrawingFile = drawingFilename
        Else
            FindDrawingFile = ""
    Else
End Function
source: https://modthemachine.typepad.com/my_weblog/2016/01/open-drawing-from-a-part-or-assembly.html
good luck 😊
Aleksandar Krstic
Produkt- und Projektmanager
Message 4 of 21
Milan_Nosil
Thank you very much for advices @bradeneuropeArthur @fullevent .
Yes, I use Vault Basic.
The whole problem is that I need to mark which parts have their drawing (in the BOM of a main assembly drawing). I know where to find out, but I need to get the information into a printed drawing.
Thank you.
Message 5 of 21
bradeneuropeArthur
Put it in the Partslist!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 21
bradeneuropeArthur
I have a very simple solution for it.
Keep reading....
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 21
bradeneuropeArthur
For my company I have written an add in that will fill in a user property to the part or assembly "Drawing" yes or No.
In the partslist we have added a column to represent this value Drawing Yes or No.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 21
Milan_Nosil
YES - this is it, can it be solved by iLogic rule?
Message 9 of 21
bradeneuropeArthur
Yes!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 21
bradeneuropeArthur
Public Sub main()
Dim a As Application
Set a = ThisApplication
Dim b As DrawingDocument
Set b = a.ActiveDocument
Dim mdl As Document
Dim c As DrawingView
Set c = b.ActiveSheet.DrawingViews(1)
Dim d As DocumentDescriptor
Set d = c.ReferencedDocumentDescriptor
Set mdl = d.ReferencedDocument
'Dim prp As Property
On Error Resume Next
Call mdl.PropertySets.Item(4).Add("Yes", "Drawing")
End Sub
for ilogic:
Public Sub main()
a = ThisApplication
Dim mdl As Document
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 21
WCrihfield
Here is probably the most simple way to check if any model has a drawing, using iLogic code.
Dim oFileName As String = ThisDoc.FileName(False)
Dim oPath As String = ThisDoc.Path
If System.IO.File.Exists(oPath & "\" & oFileName & ".idw") = True Then
	MsgBox("Yes. This model has a Drawing file.")
	'Do what you want
ElseIf System.IO.File.Exists(oPath & "\" & oFileName & ".idw") = False Then
	MsgBox("No. This model does not have a Drawing file.")
	'Do what you want
Wesley Crihfield
(Not an Autodesk Employee)
Message 12 of 21
bradeneuropeArthur
Hi @WCrihfield
This only works if the structure is always this way! (in the same directory)
If this is the case, then this is of course the easiest way to check.
But how to implement this is the BOM or Partslist?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 13 of 21
WCrihfield
Yes, I know.  I just meant that method of using 'System.IO.File.Exists()' to see if a file exists.
If you can get the file name by whatever means necessary, and you know the procedure for where its drawing would have been saved to, then you can use this method to see if the file exists.
Wesley Crihfield
Message 14 of 21
Milan_Nosil
Thank you very much @bradeneuropeArthur , @WCrihfield and @fullevent
Unfortunately, the rules from @bradeneuropeArthur doesn't work for me (the rule does nothing), but that is exactly what I need 🙂
Thank you.
Message 15 of 21
bradeneuropeArthur
Are you running the code from within a drawing-file, as needed?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 16 of 21
Milan_Nosil
Maybe I'm doing something wrong. I attach the screencast for sure.
Message 17 of 21
fullevent
Hi
i think you got the iProperty in this model (iam)..
The rule doesnt effect the parts/components the deeper levels..
Try running the rule in this drawing (drawing of the part):
regars
Aleksandar Krstic
Message 18 of 21
bradeneuropeArthur
Maybe the ipt file is Read-only.
For me it works!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 19 of 21
Milan_Nosil
Yes, it works! 😁 Thank you very much. That's exactly it.
Right now I have to add it to the template and run it automatically before saving the drawing document. Can I run it in bulk?
Can I run a rule to search parts in the entire assembly and trigger this new rule in their drawings?
Message 20 of 21
bradeneuropeArthur
Public Sub Main()
Dim a As Inventor.Application
a = ThisApplication
Dim mdl As Document
For Each b In a.Documents
Call mdl.PropertySets.Item(4).Add("Yes", "Drawing2")
Next
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
