iLogic change sheet name with parameters
I changed the names of the sheets to part numbers using the rules posted on the forum.Now I would like to add extra text "NOT PRINT" to name in selected sheets using the assembly parameters. I can not write a code that reads the existing name of the sheet. Where do I make a mistake? I will be grateful for your help.
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
oSheets=ThisDrawing.Document.Sheets
Dim oSheet As Sheet
Dim sSheetName As String
If Parameter("assemble.iam.item1") = False Then
oSheets.Item(30).Activate
mSheetName = oSheet.Name
ActiveSheet.Sheet.Name = mSheetName & "NOT PRINT"
Else
'do nothing
End If
If Parameter("assemble.iam.item2") = False Then
oSheets.Item(31).Activate
Else
'do nothing
End If
Owner2229
Here you go:
Dim oDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oSheets As Sheets = ThisDrawing.Document.Sheets
Dim Surfix As String = "NOT PRINT"
    Dim oSheet As Sheet = oSheets.Item(30)
    oSheet.Activate()
    oSheet.Name = oSheet.Name & Surfix
Else
    'Do nothing
End If
    Dim oSheet As Sheet = oSheets.Item(31)
    oSheet.Activate()
Else
    'Do nothing
End If
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Thank you for a quick answer but the code does not work properly. The rule activates sheet but does not add surfix 😞
Owner2229
Alright, I've done some testing and here's the correction (orange):
    oSheet.Activate()
    Dim FNP As Integer = InStrRev(oSheet.Name, ":", -1)
    oSheet.Name = Left(oSheet.Name, FNP - 1) & Surfix
Else
    'Do nothing
End If
    oSheet.Activate()
Else
    'Do nothing
End If
Mike
Now works perfectly.
Thank you very much!
