Folder based on filename
Message 1 of 8
Hi.
I jhave searched thru the forum but i can not find exactly what i am searching for.
I want to publish some files PDF´s, DXF´s DWFx´s etc.
The root folder is the same for example C:\PDF, then i need the code to create a sub folder based on the files name, and put my files there.
So if i put out a PDF and a DWFx of the file 123abc.dwg they will be saved in C:\PDF\123abc
The code i now use to save fileformats.
SyntaxEditor Code Snippet
strFolder = "C:\Users\lelo\AppData\Local\Autodesk\Autodesk Sync\Cloud\lennart.losjo\Part Drawings\" & ThisDoc.FileName(False) 'without extension
ThisDoc.Document.SaveAs(strFolder & (".dwfx") , True)
ThisDoc.Document.SaveAs(strFolder & (".pdf") , True)
ThisDoc.Document.SaveAs(strFolder & (".dxf") , True)
In this case i want to save the files to my A360 folder "part drawings" and i need the code to create a folder based on filename.
Lennart
Replies (7)
Message 2 of 8
demuff
If all you're trying to do is create the subfolders, check to see if the folder exists just in case then call mkdir:
newDir = strfolder & "\PDF"
If Dir(newDir, vbDirectory) = "" Then
    MkDir newDir
Change the "\PDF" to the text of the subfolder you want to create and insert the code before doing your SaveAs command to the newDir path.
Message 3 of 8
Hi. Thank you for the reply. I think i was unclear. The \PDF folder is static. Under the PDF folder i want to automaticly create subfolders witch name should be the same as the name of the file i want to save. Of course should it check if the folder already exists as in your code.
Med vänliga hälsningar
Lennart Losjö
Message 4 of 8
MechMachineMan
I guess you could try something like this then. Might need to mess around with where the backslashes go.
Sub Main()
    ThisDoc.Document.SaveAs(GetFolder(strFolder & "DWF\" & ThisDoc.FileName(False)) & "\" & ".dwfx", True)
    ThisDoc.Document.SaveAs(GetFolder(strFolder & "PDF\" & ThisDoc.FileName(False)) & "\" & ".pdf", True)
    ThisDoc.Document.SaveAs(GetFolder(strFolder & "DXF\" & ThisDoc.FileName(False)) & "\" & ".dxf", True)
End Sub
Function GetFolder(ostr) As String
    If Dir(ostr, vbDirectory) = "" Then
        MkDir -p ostr
    Return ostr
End Function
But if that one doesn't work, trying swapping out the function block for this:
If
(Not System.IO.Directory.Exists(ostr)) Then
System
.IO.Directory.CreateDirectory(ostr)
Return ostr
End Function
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 5 of 8
Hi. Thanks for your engagement.
Now we are getting close.
But in this case my part drawings folder are static.
If i export a drawing for example 123abc.dwg to pdf, dwfx and so on i want put all of them in a folder named 123abc.
And if i export a DXF from a sheet metal with the same name (123abc.ipt) i want to put it in the same folder named 123abc
Sorry for my lack of good explanation.
Lennart Losjö
Message 6 of 8
MechMachineMan
I would try this then.
Or does this code not save the actual files down properly, but does the location right?
Sub Main()
    oSaveNameWOExtension = GetFolder(strFolder)	& "\" & ThisDoc.FileName(False)
    ThisDoc.Document.SaveAs(oSaveNameWOExtension & ".dwfx", True)
    ThisDoc.Document.SaveAs(oSaveNameWOExtension & ".pdf", True)
    ThisDoc.Document.SaveAs(oSaveNameWOExtension & ".dxf", True)
End Sub
    If(Not System.IO.Directory.Exists(ostr)) Then
        System.IO.Directory.CreateDirectory(ostr)
    Return ostr
End Function
Justin K
Message 7 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi Justin,
Solution is almost closer to requirement. A tiny changes made to code.
Lennart - Can you please test the following code and confirm the same?
Are we in right direction to requirement?
Sub Main()
    strFolder = "C:\Users\lelo\AppData\Local\Autodesk\Autodesk Sync\Cloud\lennart.losjo\Part Drawings\"& ThisDoc.FileName(False)
End Sub
    Return ostr
End Function
Please feel free to contact if there is any doubt.
If solves your problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 8 of 8
Hi.
Perfect, exactly the function i need.
Thank you very much.
Smiley Happy
