ilogic: Change layer of part-sketch in drawing
c_stulz
c_stulz
here is my Idea I want to realise.
- I placed an Assambly on my drawing
- In one Part of the Assambly i switch a Sketch to visible
- Now I want A: switch this Sketch between visible or NonVosible with iLogic
I have an sample, where I find this Sketch in Browsernodes:
Sub Main()
Dim oDrwDoc As DrawingDocument
	oDrwDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
    oSheet = oDrwDoc.ActiveSheet
Dim oBrowserPanes As BrowserPanes
	oBrowserPanes = oDrwDoc.BrowserPanes
Dim oBrowserNode As BrowserNode
	oBrowserNode = oBrowserPanes.Item(1).TopNode.BrowserNodes.Item(2).BrowserNodes.Item(3).BrowserNodes.Item(1).BrowserNodes.Item(7).BrowserNodes.Item(7)
	oBrowserNode.Visible = False	' makes only the BrowserNode Unvisible and not the sketch in Drawing
	'oBrowserNode.DoSelect			' select the Browsernode
End Sub
When I go to switch Visible = False Only the Browsernode will go to invisible.
With "oBrowserNode.DoSelect" I can select the BrowserNode, but I can't find a way to make the sketch invisible like I do it with the kontextmenue by my self.
Any Idea?
Greatings Christoph
c_stulz
my second way I tried was to switch every Sketchline to an other Layer.
Sub Main()
' Define Variables
	Dim oSheet As Sheet
	Dim oAsmDoc As AssemblyDocument = ThisDrawing.ModelDocument
	Dim oOcc As ComponentOccurrence
	Dim oOccs As ComponentOccurrences
		oOccs = oAsmDoc.ComponentDefinition.Occurrences
	Dim oPrtDef As ComponentDefinition
	Dim oSketches As PlanarSketches
	Dim oSketch As PlanarSketch
	Dim oSketchLines As SketchLines
	Dim oSketchLine As SketchLine
' Search first Sketchline in Sketch (later is used for all Lines)
	For Each oOcc In oOccs
		If oOcc.Name = "Test_BT:1" Then
			oPrtDef = oOcc.Definition
			oSketches = oPrtDef.Sketches
			oSketch = oSketches.Item(2)
			oSketchLines = oSketch.SketchLines
			oSketchLine = oSketchLines.Item(1)
	Next
' Get the needed DrawingView
	Dim oDrawViews As DrawingViews
	Dim oDrawView As DrawingView
	Dim oView As DrawingView
		For Each oDrawView In oSheet.DrawingViews
			If oDrawView.Name = "ANSICHT1" Then
				oView = oDrawView
		Next
	' Search for DrawingCurve
        Dim oDrawCurve As DrawingCurve
		Dim oDrawViewCurves As DrawingCurvesEnumerator
			oDrawViewCurves = oView.DrawingCurves(oSketchLine)    ' ERROR: I think here is a SketchLineProxy nessesary
			oDrawCurve = oDrawViewCurves.Item(1)
		Dim oLayers As LayersEnumerator = oDrwDoc.StylesManager.Layers
		Dim oLayer As Layer = oLayers.Item("LayerRot")
		oDrawCurve.Segments.Item(1).Layer = oLayer
End Sub
 This Code based on a way I use Sketchlines for plasing dimensions. In that case I go and search the sketchlines wich has attributes.
The big different there is:
I search and get SketchLinieProxys insted of SketchLines.
And with the SketchlineProxys I get there allthough the equivalent DrawingCurve.
I apologize for my bad english and the bad explanation 😞
Greatings Christoph
c_stulz
So, I could find the missing step.
I had to make a SketchProxy by my one. Then I can set the Sketch(Proxy) Visible or not. Allthogh I can change the Layer of the Sketchlines.
Here is the sample:
Sub Main()
' Define Variables
	Dim oSheet As Sheet
	Dim oSketchProxy As PlanarSketchProxy
			oOcc.CreateGeometryProxy(oSketch, oSketchProxy)
	Next
				oView = oDrawView
		Next
	' Set Visibility of SketchProxy
		oView.SetVisibility(oSketchProxy, True)
	' Search for first DrawingCurve of SketchProxy to change Layer
			oDrawViewCurves = oView.DrawingCurves(oSketchProxy)    ' It works now with SketchProxy
End Sub
