Compare components - Mass Properties check - what is Task Scheduler checking
Simple question:
What method is the task scheduler using when it passes or fails a file during migration with a "Mass Properties check error"?
What I am trying to accomplish:
I would like to use a similar method - or perhaps someone could propose a better one, to test if file X is the same physical part as file Y. I do not care about differences in properties stored in the file, I want to test physical geometry only.
More info:
A company I'm working with creates custom machines. They use a project based methodology and skeletal modeling where each machine and its components reside in a project folder. Part numbers are unique to each machine. This makes part reuse across projects very difficult/limiting. Many of these machines are copied from a previous similar job using Vault Copy Design. In a high volume mfg operation, these components would be reused, but they need to be unique for this situation, even if they are actually identical (which is often the case, and the issue I am trying to streamline).
The nesting, routing and operation information is input and stored in our ERP system for each brand new file and a "library part file" is stored in our nesting and our forming software with any lead-inns or adjustments that the operator made during mfg. When we do a copy design in Vault, the original file name is pushed into a ref field in the new files. So, I want to test a copied part against its reference (original) part. If it is physically the same part (with different property info - and the referenceDesignator may or may not match), copy the ERP info, routings etc, (burn/punch/form) and by-pass any manual entry. Or else, treat it as a new file.
Any suggestions would be welcomed.
Tim
