iLogic change Filename
I am trying to make a rule in one assembly that changes the parameters of a part in it, like this:
Parameter("PERFIL UEEE.IPT", "d7")=COMPRIMENTO
But sometimes i have the necessity of changing the part filename and when i change it, the rule enters in error state because the filename changed, how can i make the rule "refresh" the part filename, PERFIL UEEE.IPT
You need to "stabalize" the name of the part
With the assembly open look for the part in the model tree. Rename the part in the model tree
Example rename "PERFIL UEEE" to "MY_PART"
Then use that in your rule
Parameter("MY_PART.IPT", "d7")=COMPRIMENTO
Right, that's usefull! 🙂
But imagine that i can't "control" the Part name, is there a way that i can make a rule that goes read the current name of the Part end then use it?
Let me try to explain another way.
When you rename the part in the model tree it retains that name even
when you do a replace or change ipart members.
So it remains constant the file name is irrelevant for the ilogic rule.
The rule uses the model tree name not the file name. So it will work
everytime regardless of which file name the part has.
I understand that, i didn't explain entirely the case, so i have my original IAM and PART:
RFORÇO.IAM---> PERFIL UEE.IPT
Then I run this in a database program and it gives the IAM and PART new references to the files names, that are the same in the model tree name, for example:
1A300.IAM--->1A301.IPT
And, to my knowledge today, i can't change the names in the model tree,  so I was wondering if I can, with a rule, "read" the new names and use them to update the rules with the new names.
Was I clear? Hope so.
And thank you for the time spending with me.
MechMachineMan
And I'm guessing the rules that reference the component/part names are in those parts?
Best solution I see is to write another iLogic that is run DURING THE RULE THAT CHANGES THE NAME that will go into the part's iLogic rule TEXT and replace String A with String B. String A being the old file name, and string B being the new file name.
Look into this thread for more info on iLogic Documentation.
https://forums.autodesk.com/t5/inventor-customization/ilogic-api-documentation/m-p/6785772/highlight...
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
