iLogic - Change BOM Structure from Default(Reference)
Context:
Inventor 2016, In an assembly, using iLogic, changing the BOM structure.
Code:
'Sets BOM Structure to Default (Remove from BOM)
Component.InventorComponent("Hardware (1):1").BOMStructure = BOMStructureEnum.kDefaultBOMStructure
ThisDoc.Save
Problem:
When I use iLogic to change the BOM structure of a component from Reference to Default I get the following situation
It shows as Default(Reference) in the browser, and still reference in the BOM. It should be Default in both.
Anyone encountered this problem before? Any help would be much appreciated!
Cheers,
Ben
MechMachineMan
No, that is as expected.
What you see in the BOM is the DOCUMENT BOM Structure settings that is applied as the default you see in the right click context menu.
The right click context menu is for the OCCURRENCE BOM Structure and will only change the BOM Structure of the occurrence.
In order to change the document BOM Structure, you need to access the document object rather than just the occurrence.
This can be done by something like...
ThisApplication.ActiveDocument.Occurrences.OccurrenceByName("OccurrenceName").Defintion.Document.BOMStructure.
Use the inventor Programming help as found through the inventor window by the "x" and it will eventually lead you to the right syntax.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
