12:41 AM
- Mute
- Permalink
- Report
Can anyone help? I am quite new in iLogic. I would like to create an iLogic rule which will be triggered by event "Before Save Document". The rule should check whether valid material is assigned to the part and if not it should cancel tha save operation so user can assign correct material to it and try to save again. The only thing which I can't find how to do it is to cancel the save operation. Is there a way how to cancel the save operation by iLogic?
Thank you.
