ilogic - attach folder contents
Hi everyone 🙂
Does anyone have some code that they could kindly share - OR - point me in the right direction to attaching the contents of a given folder to an email.
I dont want to attach a compressed file (zip) just to attach the entire contents of a folder.. it could be for pdf files only or for any file extension.
I've spent a few hours on this and got no where fast... attaching a single file is something within my ability but sadly I'm lost with regards attaching multiple files
many thanks to all who reply...
b
Owner2229
Hi, see the code below. You should modify the blue hightlighted parts.
'send email using outlook
Dim oOApp
Dim oOMail
oOApp = CreateObject("Outlook.Application")
oOMail = oOApp.CreateItem(olMailItem)
Dim olNs
olNs = oOApp.GetNamespace("MAPI")
olNs.Logon
'you can use this to select path manualy Dim dialog = New System.Windows.Forms.FolderBrowserDialog() dialog.SelectedPath = ThisDoc.Path dialog.ShowNewFolderButton = True If System.Windows.Forms.DialogResult.OK = dialog.ShowDialog() Then oPath = dialog.SelectedPath Else Exit Sub End If
'or use this to select path of currently opened file (you have to uncomment it) 'oPath = ThisDoc.Path
With oOMail .To = "someone@something.com" .Subject = "Some Subject Line Here" .Body = "Some Text Here" 'Add attachments to the message For Each oFile In System.IO.Directory.GetFiles(oPath, "*.pdf") objOutlookAttach = .Attachments.Add(oFile) Next
'send the email instantly, otherwise just saves it to folder "for send" .Send End With
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
I am owe you several virtual beers Mike! 🙂
interstingly enough, a bit of that code is exactly what I needed for another rule too but was uinsure how to implement..
I need to sit down and get my head around msdn / vb...
many thanks again!! most appreciated!!
Owner2229
You're welcomed 🙂
Mike
