ilogic and work plane visibility
Message 1 of 40
Is there a way to turn off visibility on work planes using ilogic?   Also, is there a way to change an extrusion type from an assymetrical extrusion to a one direction extrusion using ilogic?
Replies (39)
Message 21 of 40
CJ.10E-10mm
Hi Curtis,
I came across your comprehensive reply and wondered if you could help me with a simpler problem please?
I have an assembly made up of identical sub assembles which in turn deploy identical parts. Thus I want to be able to turn off all work planes and just select a particular workplane in a particular sub-assembly to switch on and then off when I have finished with it. Otherwise my model is obscured often by hundreds of identical workplanes. At the moment I am having to select them individually in the Browser.
Thus I want a message box that allows me to turn on the workplane which I have physically selected in my browser. So that after selecting a particular work plane I could then choose either the 'Visible' or 'Invisible' Button in my message Box.
I am not sure if you will receive this message but if you do and you can help I would be most and I do mean MOST grateful.
Thank you.
CJ
Message 22 of 40
niksasa
Curtis_Waguespack написано:
Hi rjones0215,
Here's another rule that toggles all of the workplanes on/off.
I hope this helps.
Curtis
'define document
Dim oDoc As PartDocument
oDoc = ThisDoc.Document
'look at the workplane collection
For Each oWorkPlane In oDoc.ComponentDefinition.WorkPlanes
'toggle all work planes
If oWorkPlane.Visible = True Then
oWorkPlane.Visible = False
ElseIf oWorkPlane.Visible = False Then
Next
If you want to turn on the visibility of a specified component?
ThisApplication.CommandManager.Pick (SelectionFilterEnum.kAssemblyOccurrenceFilter, "Select component")
САПР - это инструмент, но только при условии грамотного подхода.
Message 23 of 40
CJ.10E-10mm
Hi Niksasa,
I am most grateful but can you help further please with this error message:
Error in rule: WorkPlanes, in document: ???.iam
Unable to cast COM object of type 'Inventor._DocumentClass' to interface type 'Inventor.PartDocument'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{29F0D463-C114-11D2-B77F-0060B0F159EF}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
As I am in the top level Assembly with sub assemblies within sub assemblies and I too would like to be able to control all work features; would I be better using Curtis' alternative proposal of:
'get user input
oInput = InputRadioBox("Select work feature visibility:", _
 "Turn ON work features for all components", _
 "Turn OFF work features for all components", "False", "iLogic")
' set a reference to the assembly component definintion.
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'Define the open document (top level assembly)
Dim openDoc As Document
openDoc = ThisDoc.Document
'define view rep
Dim oViewRep As DesignViewRepresentation
Dim sVRep as String
'change to something else if Default is used for something already
sVRep = "Default"
'create or activate view rep in the top level assembly
Try
oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Item(sVRep).Activate
Catch
'create new View Rep
oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Add(sVRep)
End Try
'create or activate view rep in subassemblies
Dim docFile As Document
For Each docFile In openDoc.AllReferencedDocuments
Dim subDoc As AssemblyComponentDefinition
If docFile.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
subDoc = docFile.ComponentDefinition
Try
subDoc.RepresentationsManager.DesignViewRepresentations.Item(sVRep).Activate
Catch
subDoc.RepresentationsManager.DesignViewRepresentations.Add(sVRep)
End Try
Else
Next
    'toggle work features in the open document (top level assembly)
    For Each oWorkPlane In openDoc.ComponentDefinition.WorkPlanes
    If oInput = True Then
    ElseIf oInput = False Then
    Next
    For Each oWorkAxis In openDoc.ComponentDefinition.WorkAxes
    oWorkAxis.Visible = True
    oWorkAxis.Visible = False
    Next
    For Each oWorkPoint In openDoc.ComponentDefinition.WorkPoints
    oWorkPoint.Visible = True
    oWorkPoint.Visible = False
    Next
'look at only the subassemblies
Dim subDocFile As Document
For each oCompOcc in oAsmCompDef.Occurrences
If oCompOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
oCompOcc.SetDesignViewRepresentation(sVRep,, True) 'True sets the view rep to be associative
Else
Next
'Look at all of the files referenced in the open document
    'toggle work features in the components
    For Each oWorkPlane In docFile.ComponentDefinition.WorkPlanes
    Next
    For Each oWorkAxis In docFile.ComponentDefinition.WorkAxes
    Next
    For Each oWorkPoint In docFile.ComponentDefinition.WorkPoints
    Next
Next
iLogicVb.UpdateWhenDone = True
Although this returns the error of:
Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
Can you help further please?
Many, many thanks,
CJ
Message 24 of 40
niksasa
CJ.10E-10mm написано:
Hi Niksasa,
Many, many thanks,
CJ
Hi CJ. I'm new to ilogic. So do not know if I can help
PS: sorry for bad english
Message 25 of 40
CJ.10E-10mm
Not a problem Nicksasa,
Join the club! lol.
CJ
Message 26 of 40
Millehuse
I'm playing around with sample #4 - cause I often find myself opening old assemblies and being confronted with a million (at least) work planes, axis' odd stuff (see attachment) - and having to turn the visibility off manually - is time consuming.
I know you can hide the work features easilly with "Object Visibility" - but I want to turn the visibility off completely as part of our cleanup routine.
I get the following error though - when using sample #4 iLogic
Error in rule: WP, in document: 810.50.001.IAM
Member not found. (Exception from HRESULT: 0x80020003 (DISP_E_MEMBERNOTFOUND))
System.Runtime.InteropServices.COMException (0x80020003): Member not found. (Exception from HRESULT: 0x80020003 (DISP_E_MEMBERNOTFOUND))
   at Microsoft.VisualBasic.CompilerServices.LateBinding.LateGet(Object o, Type objType, String name, Object[] args, String[] paramnames, Boolean[] CopyBack)
   at LmiRuleScript.Main()
   at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
   at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Edited: Should clarify - it's the modified version of sample #4 - that handles all work features - not just work planes
Added extra error code information
Any thoughts?
Message 27 of 40
A small addition to make also sketches invisible.
Thanks for the source !!
For Each oSketches In openDoc.ComponentDefinition.Sketches
    oSketches.Visible = True
    oSketches.Visible = False
    Next
and
    For Each oSketches In docFile.ComponentDefinition.Sketches
    Next
'get user input
'define view rep
Dim sVRep As String
sVRep = "Default"
Try
Catch
End Try
Try
Catch
End Try
Else
Next
    Next
    Next
    Next
    Next
For Each oCompOcc in oAsmCompDef.Occurrences
Else
Next
    Next
    Next
    Next
    Next
Next
Message 28 of 40
CJ.10E-10mm
Dear nomé,
Thank you for your kind contribution.
I will try this out tonight and revert back to you.
Thank you once again.
CJJ
Message 29 of 40
amichaudJ6E3R
Hi Curtis,
I'm looking to do something similar, but maybe simpler. I have this assembly with parts in it. I want to be able to toggle the visibility of workplanes in specific components. Not all of them at the same time. Is it possible?
'catch and skip errors
On Error Resume Next
'define the active assembly
Dim oAssyDoc As AssemblyDocument
oAssyDoc = ThisApplication.ActiveDocument
'get user input as True or False
wfBoolean = InputRadioBox("Turn all Work Features On/Off", "On", "Off", False, "iLogic")
'Check all referenced docs
Dim oDoc As Inventor.Document
For Each oDoc In oAssyDoc.AllReferencedDocuments
    'set work plane visibility
    oWorkPlane.Visible = wfBoolean
    Next
    'set work axis visibility
    For Each oWorkAxis In oDoc.ComponentDefinition.WorkAxes
    oWorkAxis.Visible = wfBoolean
    Next
    'set work point visibility
    For Each oWorkPoint In oDoc.ComponentDefinition.WorkPoints
    oWorkPoint.Visible = wfBoolean
    Next
    'set sketch visibility
    For Each oSketch In oDoc.ComponentDefinition.Sketches
    oSketch.Visible = wfBoolean
    Next
Next
'update the files
InventorVb.DocumentUpdate()
I found this snippet online (that I think you may have wrote?) Anyway, I tried using as is, didn't work. I tried modifying it to fit my needs, didn't work either.
Message 30 of 40
caroline_ccc
Can use this to turn off all work features.
ThisDoc.Document.ObjectVisibility.AllWorkFeatures = False
Message 31 of 40
fixmepm
Hi. Thanks for the code. how can i make it work for CC parts as well?
Message 32 of 40
CJ.10E-10mm
I was not the source of the Code, just a hapless repeater. Sorry.
Message 33 of 40
kresh.bell
Hi @Curtis_Waguespack
this is a great iLogic, very useful. Would you modify it? When it is run, to turn off the visibility of all working planes without asking. Also without the option to make them visible. Also for sketches
Message 34 of 40
Curtis_Waguespack
Hi @kresh.bell, see this example.
Hope that helps, Curtis
Sub Main
	'define view rep
	Dim sVRep As String
	sVRep = "Default"
	Try
	Catch
	End Try
			Try
			Catch
			End Try
	Next
	'turn off features in top level
	Call TurnOff(openDoc)
	For Each oCompOcc In oAsmCompDef.Occurrences
			oCompOcc.SetDesignViewRepresentation(sVRep, , True) 'True sets the view rep to be associative
	Next
		Call TurnOff(docFile)
	Next
End Sub
Sub TurnOff(oDoc As Document)
	Dim oDef As ComponentDefinition = oDoc.ComponentDefinition
	For Each oWorkPlane In oDef.WorkPlanes
	Next
	For Each oWorkAxis In oDef.WorkAxes
	Next
	For Each oWorkPoint In oDef.WorkPoints
	Next
	For Each oSketch In oDef.Sketches
		oSketch.Visible = False
	Next
End Sub
Message 35 of 40
Curtis_Waguespack
Hi @fixmepm, here are 2 versions that will handle CC parts also.
Hope this helps, Curtis
This version just turns everything off:
Sub Main
	Dim openDoc As Document = ThisDoc.Document
	'define view rep
	Dim sVRep As String = "Default"
	Try
	Catch
	End Try
			Try
			Catch
			End Try
	Next
	For Each oCompOcc As ComponentOccurrence In oAsmCompDef.Occurrences
		Else
			If oCompOcc.Definition.IsContentMember = True Then oCompOcc.Visible = False
	Next
	Next
End Sub
	Next
	Next
	Next
	Next
End Sub
This version turns things on or off:
Sub main
	'get user input
	"Turn ON work feats, sketches, CC parts", _
	"Turn OFF work feats, sketches, CC parts", "False", "iLogic")
	'define view rep
	Try
	Catch
	End Try
			Try
			Catch
			End Try
	Next
	'set visibility work features in the open document (top level assembly)
	Call SetVis(openDoc, oInput)
		Else
			'handle Content Center Parts
			If oCompOcc.Definition.IsContentMember = True Then oCompOcc.Visible = oInput
	Next
		'set visibility or work features
		Call SetVis(docFile, oInput)
	Next
End Sub
Sub SetVis(oDoc As Document, oInput As Boolean)
		oWorkPlane.Visible = oInput
	Next
		oWorkAxis.Visible = oInput
	Next
		oWorkPoint.Visible = oInput
	Next
		oSketch.Visible = oInput
	Next
End Sub
Message 36 of 40
fixmepm
@Curtis_Waguespackworked but not for CC parts. Thanks again
Message 37 of 40
fixmepm
Im using Inventor 2019, does it matter for ilogic?
Message 38 of 40
Curtis_Waguespack
@fixmepm, 2019 should not be a factor.
I'll need more information about your CC parts to understand why it doesn't work on your end. It worked on my test assembly with standard cap screws that were placed from CC.
Also, be sure you're using one of the versions from post 35 and not post 34
Message 39 of 40
kresh.bell
Thanks @Curtis_Waguespack
perfect, works for me
Message 40 of 40
fixmepm
Im a bit confused. Is this script supposed to turn work features of the assembly on/off? i was looking for something to turn on / off work features of the different parts. I im trying to achieve another illogic that handles CC parts as well, and I want to see how to access CC via the script. im not a programmer but trying my best..
