iLogic and sketch symbol library
I have a code that looks for a yes or no iproperty from the idw model and place a sketch symbol in the idw depending on the yes or no.
I am currently using these line of code to get the sketch symbol
SyntaxEditor Code Snippet
    'create insertion point, coordinates - are cm
    Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
    Dim oInsertionPoint As Point2d
    'define the insert point for the symbol
    oInsertionPoint = oTG.CreatePoint2d(23.9,4.5) ' X = 25 cm , Y = 4.5 cm
    'define symbol Definition to use
    oSymDef= oDrawDoc.SketchedSymbolDefinitions.Item(sSymbol_01)
    'capture the current active sheet
    Dim oCurrentNumber  As Sheet
    oCurrentNumber  = oDrawDoc.ActiveSheet
        'insert the new symbol
        'Nothing is used when teh symbol has no prompted entry
        oSym = oCurrentNumber.SketchedSymbols.Add(oSymDef,oInsertionPoint,0,1,Nothing)
But it doesn't look for the skecth symbol in the libraries, only in the local one.
Is there a way (ilogic code) to insert a sketch symbol from the library?
I know that there's code to get the sketch symbol from a template but I really wish I could just use the one in the library.
UP!
BrandonBG
Dim oSketchSymLib As SketchedSymbolDefinitionLibrary
oSketchSymLib = oDrawing.SketchedSymbolDefinitions.SketchedSymbolDefinitionLibraries.Item("Library")
Dim oSSDEf As SketchedSymbolDefinition
oSSDef = oDrawing.SketchedSymbolDefinitions.AddFromLibrary(oSketchSymLib, "The Name Of The Sketched Symbol", True)
You need to add the library sketched symbol to the local symbols before you can place it.
Brandon
Thanks I just added it to my to my code and it worked!
JorisSteurs1246
I have been putting these pieces of iLogic together, but can't get it to work.
Is it possible to post the complete working code here?
Thank you.
bradeneuropeArthur
Please provide us your complete code.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
edward.bolanos
Hi
This is the rule!
Regards
'Sub Main()
'Set a reference to the drawing document.
'This assumes the drawing document is active.
Dim oDrawDoc As DrawingDocument = ThisDrawing.Document
Dim oSketchSymLib As SketchedSymbolDefinitionLibrary _
    = oDrawDoc.SketchedSymbolDefinitions.SketchedSymbolDefinitionLibraries.Item("Library")
Dim oSSDEf As SketchedSymbolDefinition _
    = oDrawDoc.SketchedSymbolDefinitions.AddFromLibrary(oSketchSymLib, "The Name Of The Sketched Symbol", True)
'Dim oDrawDoc As DrawingDocument = ThisDrawing.Document
Dim oSketchedSymbolDef As SketchedSymbolDefinition _
       = oDrawDoc.SketchedSymbolDefinitions.Item("The Name Of The Sketched Symbol")
Dim oSheet As Sheet = oDrawDoc.ActiveSheet
'CREATE INSERTION POINT, coordinates in cm!
Dim oInsertionPoint As Point2d = oTG.CreatePoint2d(24.9, 19.1)
'Add an instance of the sketched symbol definition to the sheet.
'Angle of rotation = 0 radians,
'scale = 1 when adding
'no text message
Dim oSketchedSymbol As SketchedSymbol _
       = oSheet.SketchedSymbols.Add( _
             oSketchedSymbolDef, _
             oInsertionPoint, _
             0, 1, Nothing)
'End Sub
