Ignore error on Transaction Abort
philip1009
Advisor Advisor
philip1009
I have a rule that's encompassed in a single transaction so if an error occurs it will abort and send the model back to it's previous state, but when it's aborted it still generates an error to click out of.  Here's the code sample below:
SyntaxEditor Code Snippet
oTxn=ThisApplication.TransactionManager.StartTransaction(ThisApplication.ActiveDocument,"Add Component")
On Error Goto Abort
'Bulk of Code
Goto EndRule
Abort:oTxn.Abort
EndRule:oTxn.End
Is there a way to evoke the oTxn.Abort line without generating an error pop-up?
Thanks in advance.
Philip Martick
Inventor 2018 Pro, AutoCAD 2018, Autodesk Vault Basic 2018
Windows 10 Pro
2X Intel Xeon E5-2630 v4 @ 2.20GHz
16.00 GB of RAM
NVIDIA Qudaro M2000
MechMachineMan
It's not entirely clear what error you are having to click out of....
Sub Main()
oTxn=ThisApplication.TransactionManager.StartTransaction(ThisApplication.ActiveDocument,"Add Component") On Error Goto Abort 'Bulk of Code
Goto EndRule Abort:
oTxn.Abort Exit Sub EndRule:
oTxn.End
End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
philip1009
I just figured out that you don't need to have a Transaction End after a Transaction Abort, I think trying to end a transaction after it's been aborted was generating the error.  The end of the rule just had to be rearranged like so:
On Error Goto Abort
'Bulk of Code
oTxn.End
Goto EndRule
Abort:oTxn.Abort
EndRule:
On an error, the transaction is aborted and the rule ends, otherwise the code completed successfully and the transaction ends.
