Hi @Raider_71. Here is a self help tool you can use for those types of situations. I use this fairly often for helping others with these types of questions. It uses the iLogic Logger, which became available in 2019 I believe, so if you have an earlier version, you may need to use an alternate means of writing out or showing the results.
Sub Main
Dim oDoc As Document = ThisDoc.Document
Dim oTranslator As TranslatorAddIn
For Each oAppAddin As ApplicationAddIn In ThisApplication.ApplicationAddIns
If oAppAddin.DisplayName = "Translator: IGES" Then
oTranslator = oAppAddin
End If
Next
LogTranslatorOptions(oDoc, oTranslator)
End Sub
Sub LogTranslatorOptions(oDocToExp As Document, oTransAddIn As TranslatorAddIn)
Dim oContext As TranslationContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kUnspecifiedIOMechanism
Dim oOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
If oTransAddIn.HasSaveCopyAsOptions(oDocToExp, oContext, oOptions) Then
Dim oItem As Integer = 1
For Each oPair In oOptions
Logger.Trace("Option Name = " & oOptions.Name(oItem) & vbCrLf & "Option Value = " & oOptions.Value(oOptions.Name(oItem)).ToString)
oItem = oItem + 1
Next
End If
End Sub
I'm using 2022.4, and got the following results:
INFO| 1: >>---------------------------
TRACE|Option Name = IncludeSketches
Option Value = True
TRACE|Option Name = GeometryType
Option Value = 1
TRACE|Option Name = SurfaceType
Option Value = 0
TRACE|Option Name = SolidFaceType
Option Value = 0
TRACE|Option Name = export_fit_tolerance
Option Value = 0.001
Wesley Crihfield
(Not an Autodesk Employee)
