Not sure if it helps you but if Inventor is not running you can set the active project by setting the registry key with the path of the project file:
HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersionXX.0\System\Preferences\FileDialog\LastProjectFile
(Replace XX with the version number of your Inventor version)
I would not know how to get the list of projects without an Inventor.application object. But maybe you know that they are all saved in 1 directory and leverage that knowledge?
if you have the Inventor.Application object then it's easy. This is how you get the list:
For Each projectFile As DesignProject In ThisApplication.DesignProjectManager.DesignProjects
logger.Info(projectFile.Name & " - " & projectFile.FullFileName)
Next
activating a project file is as simple as getting the project object and activating it:
ThisApplication.DesignProjectManager.DesignProjects.ItemByName("MyProject").Activate()
This will only work if there are none documents open.
Jelte de Jong
Blog: hjalte.nl - github.com
