List all projects in Visual Studio
rbertoletti
rbertoletti
Hi everyone,
i'm creating a form where by clicking a button i'm able to list all the inventor projects in flowlayoutpanel in order to select one to work on.
Someone knows how to write the code?
Thanks in advance for the support.
Michael.Navara
Do you run your Form inside Inventor process (in AddIn) or outside (standalone EXE)?
In the first case you can use DesignProjectManager Object to obtain all available projects
In the second case I recommend you to use Ipj.exe from Inventor installation folder to switch projects. Default path: "C:\Program Files\Autodesk\Inventor 2023\Bin\Ipj.exe"
Or you can try to use ApprenticeServer, but I have no experience with switching projects this way.
rbertoletti
I'm managing inventor through an exe file.
My intention is to show in the indicated area all the projects in order to select one and after press the button confirm.
JelteDeJong
Not sure if it helps you but if Inventor is not running you can set the active project by setting the registry key with the path of the project file:
HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersionXX.0\System\Preferences\FileDialog\LastProjectFile
(Replace XX with the version number of your Inventor version)
I would not know how to get the list of projects without an Inventor.application object. But maybe you know that they are all saved in 1 directory and leverage that knowledge?
if you have the Inventor.Application object then it's easy. This is how you get the list:
For Each projectFile As DesignProject In ThisApplication.DesignProjectManager.DesignProjects
    logger.Info(projectFile.Name & " - " & projectFile.FullFileName)
Next
activating a project file is as simple as getting the project object and activating it:
ThisApplication.DesignProjectManager.DesignProjects.ItemByName("MyProject").Activate()
This will only work if there are none documents open.
Jelte de Jong
Blog: hjalte.nl - github.com
