iFeature.FindRow causes "Cannot change that row" error
lweymouth5
lweymouth5
Hi, I have this snippet of code which finds the next suitable row for an iFeature and it works about 20% of the time. However, more often than not, I get the error:
"System.ArgumentException: iFeature.FindRow("iFeatureName"): Cannot change the row." on row 3
(I've changed the name of the iFeature here to generic due to work IP)
Below is the snippet of code which is causing the headache.
	Logger.Warn("Starting base member check")
Try
	i = iFeature.FindRow("iFeatureName", "b1", "=", BASE_ANGLE_A, "b2", "=", BASE_ANGLE_A, "t", ">=", BASE_ANGLE_t - 0.5)
	Logger.Warn("Currently Selected row " & i)
Catch ex As Exception
	Logger.Error("Error is: " & ex.ToString)
	Exit Sub
End Try
Try
	iFeature.ChangeRow("iFeatureName", i)
	Logger.Warn("Struggling to change to the selected row")
End Try
the double try was just to identify where the error was occurring, which happened to be assigning when "i"
I'm really struggling here as I'm only trying to read the row using
i = iFeature.FindRow("iFeatureName",...........
and I'm getting a change row error. Am I accidentally modifying the iFeature with this one or accessing it incorrectly?
Again, it definitely has worked before but is inconsistent.
Any feedback is greatly appreciated
bradeneuropeArthur
could you share that ifeature?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
