IDW Revision Table Numbering Customization
Hi Everyone
I have a Question.
Is it possible to set the default revision numbering system from Numerical to Alphabetical?
BrandonBG
Not by default, but you can set the Revision Number iProperty to anything you want, not just a number.
Assuming you want to go A B C D . . . , you could write an iLogic rule that adds a revision row, then switches the new revision number to a letter. If revision equals 1, then revision equals A, etc. Or, you can just manually override it in the iProperties window.
BrandonBG
MechMachineMan
Do you even google?
https://forums.autodesk.com/t5/inventor-customization/ilogic-revision-table/td-p/5591728
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
