IDW ilogic reference point error
I have an issue with an .idw where im trying to work out a rule in iLogic that will scale my views depending on the length of a pipe that i have drawn. An example is that if the length is above 7000mm the scale is 1:55, and above 11000 the scale is 1:75 .
I have four views, the 3 normal ISO standard views + a 3D.
the code i have now gives me the error: "Object reference not set to an instance of an object."
Im assuming its the .SetSpacingToCorner code that gives me the error, and this feature is not important, i just need them splitted apart.
here is the code:
SyntaxEditor Code Snippet
If Parameter("15231.10:1", "Conveyor_Lenght")<=7000 ActiveSheet.View("VIEW1").Scale=1/45 ActiveSheet.View("VIEW3").Scale=1/55 ActiveSheet.View("VIEW5").Scale=1/55 ActiveSheet.View("VIEW1").SetSpacingToCorner(20, 80, SheetCorner.BottomLeft) ActiveSheet.View("VIEW2").SetSpacingToCorner(230, 90, SheetCorner.BottomLeft) ActiveSheet.View("VIEW3").SetSpacingToCorner(280, 40, SheetCorner.BottomLeft) ActiveSheet.View("VIEW5").SetSpacingToCorner(280, 90, SheetCorner.BottomLeft) Else If Parameter("15231.10:1", "Conveyor_Lenght")<=11000 ActiveSheet.View("VIEW1").Scale=1/65 ActiveSheet.View("VIEW3").Scale=1/75 ActiveSheet.View("VIEW5").Scale=1/65 ActiveSheet.View("VIEW1").SetSpacingToCorner(20, 80, SheetCorner.BottomLeft) ActiveSheet.View("VIEW2").SetSpacingToCorner(230, 90, SheetCorner.BottomLeft) ActiveSheet.View("VIEW3").SetSpacingToCorner(280, 40, SheetCorner.BottomLeft) ActiveSheet.View("VIEW5").SetSpacingToCorner(280, 90, SheetCorner.BottomLeft) Else If Parameter("15231.10:1", "Conveyor_Lenght")<=15000 ActiveSheet.View("VIEW1").Scale=1/85 ActiveSheet.View("VIEW3").Scale=1/95 ActiveSheet.View("VIEW5").Scale=1/85 ActiveSheet.View("VIEW1").SetSpacingToCorner(20, 80, SheetCorner.BottomLeft) ActiveSheet.View("VIEW2").SetSpacingToCorner(230, 90, SheetCorner.BottomLeft) ActiveSheet.View("VIEW3").SetSpacingToCorner(280, 40, SheetCorner.BottomLeft) ActiveSheet.View("VIEW5").SetSpacingToCorner(280, 90, SheetCorner.BottomLeft) End If ' Set a reference to the active drawing document Dim oDoc As DrawingDocument oDoc = ThisDoc.Document ' Set a reference to the active sheet Dim oSheet As Sheet oSheet = oDoc.ActiveSheet Dim oDrawingDim As DrawingDimension ' Iterate over all dimensions in the drawing and ' center them if they are linear or angular. For Each oDrawingDim In oSheet.DrawingDimensions If TypeOf oDrawingDim Is LinearGeneralDimension Or _ TypeOf oDrawingDim Is AngularGeneralDimension Then oDrawingDim.CenterText End If Next InventorVb.DocumentUpdate()
Any help?
Thank you in advance.
-A
