.idw Export .PDF with revision
GSK139
GSK139
I am trying the code of ItsaCADworld.
But I cant get the code to work. The code is the same as the one in the video.
And is it possible to automatically put "REV"_"Revision_Number" behind the exported file name?
WorkspacePath = ThisDoc.WorkspacePath()
WorkspacePathLength = Len(WorkspacePath)
PathOnly = ThisDoc.Path
DirectoryPath = Strings.Right(PathOnly, PathOnly.Length - WorkspacePathLength)
PDFPath = "C:\PDFs\" & DirectoryPath
If (Not System.IO.Directory.Exists(PDFPath)) Then
	System.IO.Directory.CreateDirectory(PDFPath)
End If
ThisDoc.Document.SaveAs(PDFPath & "\" & ThisDoc.FileName(False) & ".pdf" , True)
Ralf_Krieg
Hello
Sub main
	End If
	'ThisDoc.Document.SaveAs(PDFPath & "\" & ThisDoc.FileName(False) & ".pdf" , True)
    ' Get the PDF translator Add-In.
    Dim PDFAddIn As TranslatorAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
    Dim oContext As TranslationContext = ThisApplication.TransientObjects.CreateTranslationContext
    oContext.Type = kFileBrowseIOMechanism
    ' Create a NameValueMap object
    Dim oOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
    ' Create a DataMedium object
    Dim oDataMedium As DataMedium = ThisApplication.TransientObjects.CreateDataMedium
    ' Check whether the translator has 'SaveCopyAs' options
    If PDFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
        ' Options for drawings...
        oOptions.Value("All_Color_AS_Black") = 0
        'oOptions.Value("Remove_Line_Weights") = 0
        'oOptions.Value("Vector_Resolution") = 400
        'oOptions.Value("Sheet_Range") = kPrintAllSheets
        'oOptions.Value("Custom_Begin_Sheet") = 2
        'oOptions.Value("Custom_End_Sheet") = 4
    End If
    'Set the destination file name
    oDataMedium.FileName = PDFPath & "\" & ThisDoc.FileName(False) & ".pdf"
    'Publish document.
    Call PDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
End Sub
R. Krieg
RKW Solutions
www.rkw-solutions.com
GSK139
Thank you. Why do you need the add-in? Isnt it possible to do it without?
Ralf_Krieg
Hello
The SaveAs method does nearly the  same as if you use the "Save As" option in GUI. You can select another filename, but can not convert to a different file type. Can't believe the code works.
R. Krieg
RKW Solutions
