Create Sketch Line from Selected Point
commonmandan
commonmandan
What's wrong with the code below? It has a problem making line1A, but not line2. I've mess around quite a bit to try and get it to work. My assumption is that it has something to do with the oPoint0. I've make a longer version of this script that creates about a dozen lines, but the issue is always the first line. What am I misunderstanding about the API and points?
To use this, start a sketch in a part and drawing a line. Run this script and select the end point of the line.
Public Sub Main()
	'Start in an active sketch
	Dim oDrawDoc As PartDocument
	oDrawDoc = ThisApplication.ActiveDocument
	Dim oSketches As PlanarSketches
	oSketches = ThisApplication.ActiveDocument.ComponentDefinition.Sketches
	Dim oSketch As PlanarSketch
	If TypeOf ThisApplication.ActiveEditObject Is Sketch Then
		oSketch = ThisApplication.ActiveEditObject
	Else
		MessageBox.Show("Need to be in an Active Sketch.", "Title")
		Exit Sub
	selectedStartPoint = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchPointFilter, "Select point")
	Dim oPoint0 As Point2d
	'oPoint0 = ThisApplication.TransientGeometry.CreatePoint2d(selectedStartPoint.Geometry.X, selectedStartPoint.Geometry.Y)
	test = False
	Dim startpoint As SketchPoint
	For Each startpoint In oSketch.SketchPoints
		If startpoint.Geometry.IsEqualTo(selectedStartPoint.Geometry)
			oPoint0 = ThisApplication.TransientGeometry.CreatePoint2d(startpoint.Geometry.X, startpoint.Geometry.Y)
			test = True
	Next
	Dim oPoint1A As Point2d
	oPoint1A = ThisApplication.TransientGeometry.CreatePoint2d(line0.EndSketchPoint.Geometry.X + (1 * 2.54), line0.EndSketchPoint.Geometry.Y)
	Dim line1A As SketchLine
	linelA = oSketch.SketchLines.AddByTwoPoints(oPoint0, oPoint1A)
	' ISSUE WITH THE NEXT LINE !!!!!!!
	oSketch.GeometricConstraints.AddHorizontal(line1A)
	Dim oPoint2 As Point2d
	oPoint2 = ThisApplication.TransientGeometry.CreatePoint2d(oPoint1A.X, oPoint1A.Y + (1 * 2.54))
	Dim line2 As SketchLine
	' ISSUE WITH THE COMMENTED OUT LINE, B/C line1A IS NOT AN OBJECT?
	'line2 = oSketch.SketchLines.AddByTwoPoints(line1A.EndSketchPoint, oPoint2)
	line2 = oSketch.SketchLines.AddByTwoPoints(oPoint1A, oPoint2)
	MessageBox.Show(line2.Geometry.StartPoint.X, "Title")
	oSketch.GeometricConstraints.AddVertical(line2)
End Sub
matt_jlt
I'm not really sure what some of your code is doing, there are some redundant things like the loop that is in there. Maybe it's just a partial part of your code? When i copied your function i has errors like Line0 not defined.
I wrote something for you that is a more simple method with descriptions on how it works.
Sub Main()
	Dim oDrawDoc As PartDocument = ThisApplication.ActiveDocument
	Dim oSketches As PlanarSketches = ThisApplication.ActiveDocument.ComponentDefinition.Sketches
	Else
		MessageBox.Show("Need to be in an Active Sketch.", "Incorrect Active Object")
		Exit Sub
	Dim selPoint As SketchPoint = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchPointFilter, "Select point")
	' Check an object was selected
	If selPoint Is Nothing Then
		MessageBox.Show("No object selected", "User Selection")
		Exit Sub
	' There are multiple ways to do this, you can create sketch points and use them to create the lines (like i did for pointA) or create lines from 2dPoints not linked to sketch points like i did for PointsB + C
	' Create two points needed for line creation
	Dim oPointA As Inventor.SketchPoint = selPoint
	Dim oPointB As Inventor.Point2d = ThisApplication.TransientGeometry.CreatePoint2d(oPointA.Geometry.X, oPointA.Geometry.Y + 2.54)
	Dim oPointC As Inventor.Point2d = ThisApplication.TransientGeometry.CreatePoint2d(oPointA.Geometry.X + 2.54, oPointA.Geometry.Y)
	' Ground starting point to lock in place
	oSketch.GeometricConstraints.AddGround(oPointA)
	' Create new line object
	Dim oLine1 As Inventor.SketchLine = oSketch.SketchLines.AddByTwoPoints(oPointA,oPointB)
	' Add horizontal constraint
	oSketch.GeometricConstraints.AddHorizontal(oLine1)
	Dim oLine2 As Inventor.SketchLine = oSketch.SketchLines.AddByTwoPoints(oPointA, oPointC)
	' Add vertical constraint
	oSketch.GeometricConstraints.AddVertical(oLine2)
	' Make sketch solve / update
	oSketch.Solve
	MessageBox.Show("Line 2: " & ControlChars.NewLine & "X: " & oLine2.Geometry.StartPoint.X & " | Y: " & oLine2.Geometry.StartPoint.Y, "Line 2 Start Point")
End Sub
