IDW Converting to PDF
Cheers,
I am Attempting to write an iLogic code to save all drawing files of referenced from the top level assembly drawing as PDFs. My code is saving the top level but not saving the other parts. I am trying to save them in my R: drive separate from the vault work space location so all on my server can access. I have attached my code. Any help is appreciated.
Thank You,
Josh
NSBowser
Josh,
Your Saving each PDF successfully, unfortunately your saving them all with the Assembly Filename.
Near the beginning of your code you call:
oFileName = ThisDoc.FileName(False) 'without extension
While looping through the oRefDocs, you again call:
oFileName = ThisDoc.FileName(False) 'without extenstion
 This isn't setting the Filename to the new, open doc, it is still setting it to ThisDoc (Being the document which contains the rule... as such ThisDoc never changes while the rule is running)
For the sub parts, I would replace it with:
oFileName =System.IO.Path.GetFileNameWithoutExtension(oDrawDoc.FullFileName)
for the Assembly, I would replace it with
oAsmDrawingName = System.IO.Path.GetFileNameWithoutExtension(oAsmDrawingDoc.FullFileName)
Additionally, I had to add a "." on the one line for
oDataMedium.FileName = oFolder & "\" & oFileName & "pdf"
to make it
oDataMedium.FileName = oFolder & "\" & oFileName & ".pdf"
Your mileage may vary, but it seems the root of your problems are filenames
Hopefully this gets you sorted out. If you need further guidance after you sort those out, let us know.
Best of Luck
If you find this reply helpful or insightful, please use the 'Accept as Solution' or 'Kudos' button below.
Thank You.  This is going to save me so much time
