change baseview with custom view orientation
Message 1 of 1
Hello
I made a code to create a view of a plate . But we work with a lot derive part. So I can not just put a top view . Now if you give a negative answer to the question "are you  happy ". I would like to open custom view orientation . Is this possible?
Imports Inventor.ViewOrientationTypeEnum
Imports Inventor.DrawingViewStyleEnum
Sub Main muppet()
Dim oDrawDoc as DrawingDocument
Dim oPartDoc as Document
Dim oSheet As sheet
Dim oTG As TransientGeometry
Dim oBaseView As DrawingView
'Ask to create drawing?
dwgQuery=MsgBox(" Create a drawing for this MODEL?", vbYesNo,"Drawing Selection")
If dwgQuery = vbYes Then
	oPartDoc = ThisDoc.Document
    'Define IDW Template File Location
    oDrawDoc = ThisApplication.Documents.Add(kDrawingDocumentObject, "C:\00-CONSTRUX LIBRARY\99-Templates\Laser.idw", True)
    oSheet = oDrawDoc.Sheets.Item(1)
    'Define 2d view bottom left corner points for four views
    oPoint1 = ThisApplication.TransientGeometry.CreatePoint2d(5, 5)
	oBaseView = oSheet.DrawingViews.AddBaseView(oPartDoc,oPoint1, 1/1,kTopViewOrientation, kHiddenLineDrawingViewStyle, "Default")
	dwgQuery=MsgBox("Happy?", vbYesNo,"test")
	If dwgQuery = vbNo Then
	MessageBox.Show("Message", "Title")   I WANT CUSTOM VIEW ORIENTATION HERE
	End Sub
The image shows what I want is this possible?
thanks in advance
Ewoud
Replies (0)
