I need to export a sheet in PLT / HPGL file
Kreshnik.HASANI
Kreshnik.HASANI
As mentioned in the title, I need to find a way to export a sheet in PLT / HPGL file using Inventor API.
I searched on the web without success.
Any idea ?
Thanks.
bradeneuropeArthur
Does this help you:
https://forums.autodesk.com/t5/inventor-customization/how-to-set-plt-prn-output-from-inventor-drawin...
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Kreshnik.HASANI
Thanks for the link.
I'm trying to implement this solution but I have some issues : I installed an HPGL Printer (hpi16gex) but when I export HPGL file, the texts are not presents in the file.
I don't know if this comes from driver or Inventor code.
Could you propose me a HPGL printer / driver for Windows 10 ?
Thanks in advance
Kreshnik.HASANI
Any other idea ?
Thanks in advance
