I-Logic for Custom properties
didin.suryadi6JREK
Message 1 of 14
didin.suryadi6JREK
Hello
Can anyone check below i-logic code?
Dim propertyName1 As String = "Rev Desc"
Dim propertyValue1 As String = ""
customPropertySet = ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties")
Try
      prop = customPropertySet.Item(propertyName1)
Catch
      customPropertySet.Add("", propertyName1)
  End Try
	Dim propertyName2 As String = "Rev Date"
Dim propertyValue2 As String = "mm/dd/yyyy"
Try
      prop = customPropertySet.Item(propertyName2)
Catch
      customPropertySet.Add("mm/dd/yyyy", propertyName2)
  End Try
	Dim propertyName3 As String = "Salvagnini Proficient"
Dim propertyValue3 As String = "Yes"
Try
      prop = customPropertySet.Item(propertyName3)
Catch
      customPropertySet.Add("Yes/No", propertyName3)
  End Try
The problem on the result i have is the "Rev Date" shown as text meanwhile the purpose i need is "Date"
and the 2nd one on string "Salvagnini proficient" it's needs to be a multpile choices 'YES'NO"
Please see attached the wrong result and what i need.Custome Properties (wrong).JPG
Replies (13)
Message 2 of 14
JhoelForshav
Hi @didin.suryadi6JREK
You must use a value of the datatype expected by the property type you want it to be.
For example, if you want a date property, the value must be of a date type.
Dim customPropertySet As PropertySet = ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties")
Try
Catch
End Try
Dim propertyValue2 As Date = Today.Date
Try
Catch
	customPropertySet.Add(propertyValue2, propertyName2)
End Try
Dim propertyValue3 As Boolean = True
Try
Catch
	customPropertySet.Add(propertyValue3, propertyName3)
End Try
Message 3 of 14
Pulled directly from the API help file.
Public Sub CreateCustomProperties()
    ' Get the active document.
    Dim invDoc As Document
    Set invDoc = ThisApplication.ActiveDocument
    ' Get the user defined (custom) property set.
    Dim invCustomPropertySet As PropertySet
    Set invCustomPropertySet = invDoc.PropertySets.Item("Inventor User Defined Properties")
    ' Declare some variables that will contain the various values.
    Dim strText As String
    Dim dblValue As Double
    Dim dtDate As Date
    Dim blYesOrNo As Boolean
    ' Set values for the variables.
    strText = "Some sample text."
    dblValue = 3.14159
    dtDate = Now
    blYesOrNo = True
    ' Create the properties.
    Dim invProperty As Property
    Set invProperty = invCustomPropertySet.Add(strText, "Test Test")
    Set invProperty = invCustomPropertySet.Add(dblValue, "Test Value")
    Set invProperty = invCustomPropertySet.Add(dtDate, "Test Date")
    Set invProperty = invCustomPropertySet.Add(blYesOrNo, "Test Yes or No")
End Sub
For a yes/no custom iProperty you will need to provide a variable with a boolean type.
Best of luck!
Message 4 of 14
didin.suryadi6JREK
HI,
I tried but came up msg error, why is that?
Message 5 of 14
didin.suryadi6JREK
hi
Thanks, but the same error msg came up
Message 6 of 14
didin.suryadi6JREK
HI, THIS IS WHAT AM TALKING ABOUT, THANKS
IT's WORKED.
Message 7 of 14
robertast
 @Anonymous      You have provided an example that runs VBA makro and you are trying to write it to iLogic. As a result, you get an error. Replace "Public Sub CreateCustomProperties ()" with "Sub main ()". And everywhere there is the word “Set”. Erase them.
And just read all @JhoelForshav  posts in this forum and you will find a lot of interesting and useful 👍
Message 8 of 14
didin.suryadi6JREK
Hi
Just come up with another question, what string do i have to put on "Rev Date" if i want it to leave empty on the first entry value, so it will be filled when we do the revision.
  Attached the final result that i wanted.
Message 9 of 14
didin.suryadi6JREK
Hi
Thanks for your correction, would you please take a look to my latest reply? on "Rev Date" i want it to leave empty on the first entry value, so it will be filled when we do the revision.
I have attached on replied with the pic that i wanted.
Appreciated your prompt reply.
Message 10 of 14
robertast
Do you use code written by  @JhoelForshav  ?
He will stop sleeping and write you an answer. If you're having trouble waiting, 🙂
try changing
"Dim propertyValue2 As Date = Today.Date"
to      Dim DimValue2 As Date = " "
Message 11 of 14
didin.suryadi6JREK
Hi Rob
sorry for hurry, he is sleeping and will read by tomorrow, so do i.
Anyway i tried with your suggestion and it looks like the string did not match,
See Attached
Message 12 of 14
robertast
Forgive me  @JhoelForshav  because I was a bad student, giving the wrong advice. 🙁
Message 13 of 14
JhoelForshav
The only way I can get this to work is to create the property with a date, then make it Null. Like this 🙂
Try
Catch
End Try
Dim propertyValue2 As Nullable(Of Date) = Date.Now
Dim NullDate As Nullable(Of Date)
Try
Catch
	iProperties.Value("Custom", propertyName2) = NullDate
End Try
Try
Catch
End Try
Message 14 of 14
didin.suryadi6JREK
Waw,,.. Its working now,
Thank You very much sir, have a good day
