HRESULT 0x80004005 (E_FAIL) when running iLogic rule on BeforeSave event
I have a rule that used to work just fine in Inventor 2017 Professionnal that no longer works in Inventor 2019 & Inventor 2020.
The rule code is the following:
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
oAsmCompDef.RepresentationsManager.LevelOfDetailRepresentations.Item("SUPPRESS_INVISIBLE_ITEMS").Activate(True)
I tested this with attached Assembly2.iam file, when hitting the save button I get the following error:
Error in rule: Rule1, in document: Assembly2.iam
Erreur non spécifiée (Exception from HRESULT: 0x80004005 (E_FAIL))
Stack trace:
System.Runtime.InteropServices.COMException (0x80004005): Erreur non spécifiée (Exception from HRESULT: 0x80004005 (E_FAIL))
   at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
   at Inventor.LevelOfDetailRepresentation.Activate(Boolean SkipDocumentSave)
   at ThisRule.Main()
   at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
   at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
This is an upgrade error from 2017 to 2019, so I would expect to get support from Autodesk.
bradeneuropeArthur
Since the LOD is not available in the assembly you need to add it first.
Try
oAsmCompDef.RepresentationsManager.LevelOfDetailRepresentations.Add("SUPPRESS_INVISIBLE_ITEMS")
Catch
	End Try
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
