How to track if geometry or mass of part/assembly has changed
goran.jutrisa
goran.jutrisa
Hi to all
In Part document there is a trigger in the tab This document, trigger Part Geometry Change.
This trigger isn't available in Part and Assemblies Tab.
I would find it useful to add a custom property timestamp (date+time) to all parts and assemblies when the mass changes.
Is there a code for something like this?
Best regards
bradeneuropeArthur
Because an assembly is only a container with models this method is not needed.
An assembly can only change if a part changes.
This means the stamp must come from the part-triggers and not from the assembly triggers.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
goran.jutrisa
Hi
The assembly changes if some mates added or changed, or just new part is added od removed.
This is something that I also want to track, every change in assembly,
