how to solve Catastrophic failure during SaveCopyAs operation during geometry export operation?
mirhan.ozdemir39YZT
Message 1 of 1
mirhan.ozdemir39YZT
Hi everyone,
I am working on a geometry export operation using VBScript, but I'm encountering an error when I try to run my script in batch mode. However, when I open the software and run the script in the VBA editor, it works perfectly.
Below is the error I receive when running it in batch mode:
The line 91 is " Call oCADTranslator.SaveCopyAs(oDoc, oContext, oOptions, oData)"
' Here is my full VBscript:
' Initialize the logging mechanism
Dim fso, logFile
Set fso = CreateObject("Scripting.FileSystemObject")
Set logFile = fso.CreateTextFile("C:\Users\wj2078\Desktop\Coding Examples\inventor_batch_mode\logfile.txt", True) ' Adjust the log file path as needed
logFile.WriteLine "Script started..."
' Initialize Inventor application
Dim oApp
Set oApp = CreateObject("Inventor.Application")
' Set Inventor to be visible (adjust to True/False based on testing needs)
oApp.Visible = False ' Set to True for visibility; False for batch mode
logFile.WriteLine "Inventor initialized. Visibility set to: " & oApp.Visible
' Check if CAD Translator Add-In is available and active
Dim oCADTranslator
Set oCADTranslator = oApp.ApplicationAddIns.ItemById("{533E9A98-FC3B-11D4-8E7E-0010B541CD80}")
If oCADTranslator Is Nothing Then
MsgBox "Could not access CAD translator."
logFile.WriteLine "CAD Translator is not available."
oApp.Quit
logFile.Close
WScript.Quit
End If
If Not oCADTranslator.Activated Then
MsgBox "Activating CAD Translator."
logFile.WriteLine "CAD Translator activated."
End If
oApp.SilentOperation = True
' Open the document
Dim oDoc
Dim filePath
filePath = "C:\Users\wj2078\Desktop\Coding Examples\inventor_batch_mode\Octet(1 0 0)_Derrived.ipt"
Set oDoc = oApp.Documents.Open(filePath, True)
' Update the document
oDoc.Update
' Ensure the document is open
If oDoc Is Nothing Then
MsgBox "Document could not be opened.", vbCritical
logFile.WriteLine "Document could not be opened: " & filePath
oApp.Quit
logFile.Close
WScript.Quit
End If
logFile.WriteLine "Document opened successfully: " & filePath
' Create a translation context
Dim oContext
Set oContext = oApp.TransientObjects.CreateTranslationContext
logFile.WriteLine "Translation context created."
' Create options for the CAD export
Dim oOptions
Set oOptions = oApp.TransientObjects.CreateNameValueMap
If oCADTranslator.HasSaveCopyAsOptions(oDoc, oContext, oOptions) Then
' Set accuracy to Medium (1) - can be adjusted to Low (0) or High (2)
oOptions.Value("Resolution") = 1
logFile.WriteLine "CAD Resolution set to Medium (1)."
' Set output file type: 0 - binary, 1 - ASCII
oOptions.Value("OutputFileType") = 0
logFile.WriteLine "CAD OutputFileType set to ASCII (1)."
oContext.Type = kFileBrowseIOMechanism
' Set up the data medium with the target file path
Dim oData
Set oData = oApp.TransientObjects.CreateDataMedium
' output file name
oData.FileName = "C:\Users\wj2078\Desktop\Coding Examples\inventor_batch_mode\Octet(1 0 0)_Derrived.stl"
logFile.WriteLine "CAD output path set: " & oData.FileName
' Export the file
logFile.WriteLine "CAD file successfully exported."
Else
logFile.WriteLine "CAD Translator did not provide SaveCopyAs options."
End If
' Save and close the document
oDoc.Save
oDoc.Close
logFile.WriteLine "Document saved and closed."
' Quit Inventor application
oApp.Quit
logFile.WriteLine "Inventor application quit."
' Close the log file
logFile.Close
'oApp.SilentOperation = False
' Notify the user (optional)
MsgBox "CAD export process completed."
'Thanks in advance for your guidance!
Replies (0)
