LeaderNote - selection from code
pawel_watroba
pawel_watroba
Hi everyone,
Is it possible to select leader note from code? When I try do it by SelectSet.Select I have an error.
Paweł
Michael.Navara
Can you be more descriptive? This code selects the first leader note on active sheet.
Dim drw As DrawingDocument = ThisDoc.Document
drw.SelectSet.Select(drw.ActiveSheet.DrawingNotes.LeaderNotes(1))
pawel_watroba
Thanks for You reply, all working. I had issue i my code, when selecting leader notes by attribute set i select other objects too.
