How to show sections views of components made using Design Accelarator
Hi ALL,
our group is facing problem in showing the section views of parts
(ex: shafts, splines etc & bearings/circlips etc ) in the assembly drawing.
How to show the sections views in the assy drawings.
Kinldy show me the procedure.
Thanks in advance
matt_jlt
Do you want to do this using the API (Macro or Addin) I'm not sure as your question is a bit vague? If not you have posted in the wrong forum. You would have had a faster response in the General Inventor questions forum.
If you want to do so using the API just tell me and I'll have a look for you.
If not and you just want to be able to section Design accelerator components manually then you can either:
Method 1:
* Change selection priority from "Edge Priority" to "Part Priority".
* Select your part to be sectioned.
* Right Click mouse button on the part.
* Select the "Section Participation" expanding menu and change section from "None" to "Section".
Method 2:
* Using the browser tree on the left, Right Click mouse button on the part.
Method 3:
Note: This will section all parts and override the previous methods if used.
* Right Click mouse button of the Section View & Click on View Properties (or just double click on the section view)
* Under the display options tab there is a drop down box that is labelled "Section Standard Parts"
* Change the value from "Obey Browser Settings" to "Always"
Hope this helps.
Regards, Matt
