Is it possible to create iAssembly?
I want to create an iAssembly by API, is it possible?
Now I already write the code to add all assembly members and ground them already.
Dim oiAsmDoc AsAssemblyDocument
oiAsmDoc = mApp.Documents.Add(DocumentTypeEnum.kAssemblyDocum​entObject)
Dim oiAsmComDef AsAssemblyComponentDefinition
oiAsmComDef = oiAsmDoc.ComponentDefinition
Dim oiTG AsTransientGeometry
oiTG = mApp.TransientGeometry
Dim oiMatrix AsMatrix
oiMatrix = oiTG.CreateMatrix
Dim f As Integer
For f = 1 To oRowNum 'oRowNum = 2
       Dim oiOcc AsComponentOccurrence
       oiOcc = oiAsmComDef.Occurrences.Add(oAsmFullFileName(f - 1), oiMatrix)
Next
Dim oiConstraint AsAssemblyConstraint
For Each oiConstraint In oiAsmComDef.Constraints
      oiConstraint.Delete()
Next
Dim oiOccurrence As ComponentOccurrence
For Each oiOccurrence In oiAsmComDef.Occurrences
         If oiOccurrence.Grounded = FalseThen
              oiOccurrence.Grounded = True
Next
mApp.SilentOperation = True
oiAsmDoc.SaveAs(oiAsmFullFileName, False)
Dim oiAsmFac AsiAssemblyFactory
oiAsmFac = oiAsmComDef.CreateFactory
Dim oiAsmRow As Integer
Dim oAsmRow(oRowNum) As iAssemblyTableRow
For oiAsmRow = 1 To (oRowNum + 1)
         CalloiAsmFac.CreateMember(oiAsmRow)       ' Error from this line
         oAsmRow(oiAsmRow - 1) = oiAsmFac.TableRows.Item(oiAsmRow)
Next
oiAsmDoc.Save()
mApp.SilentOperation = False
I wonder how can:
      I add a few row?
      I add the Include/Exclude of sub-assemblies ( which I already added upper)?
      I change the value of Include/Exclude of sub-assemblies in the specific row?
I found the solution by my self. It seem to be hard to do this only inside Inventor.
I just need to write all information that I need into the Excel Worksheet of iAssembly Table.
