How to share button constructor custom ribbon with others?
andreas.jonssonF98YC
@JelteDeJong I have used your button constructor and it works fine to add my ilogic code as buttons in the ribbon. However I would like share this ribbon with several other people on different computers. Can you explain how you can do it?
Best regards Andreas
bradeneuropeArthur
Can't you store the profile as .xml file and load this on serveral pc's?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
JelteDeJong
There is a settings file with all information on your buttons. You need to copy that file to the computer of the people you want to share your buttons with. (It is not possible to put this file in a centralized place. It needs to be in the same directory as your addin files.) Depending on how your addin is installed it can be in several places.
Have a look at the Help page on my site. In the chapter "Settings file for the addin." you will find instructions to find the settings file. You should be looking for the file: "RuleButtonSettings.Xml". That is the file that you need to copy.
Jelte de Jong
Blog: hjalte.nl - github.com
Thank you! so how can I install the addin in several locations at once? 🙂 I have found the xml
JelteDeJong
Use the installer on all computers and overwrite the original settings file with the one you found.
Jelte de Jong
thank you I will do that 🙂
