How to setting my .ARG to be default in Inventor 2010 AutoCAD
Please help me regarding with Inventor 2010 AutoCAD Options "Profile setting", i need it to be default my *.ARG, i always trying to set my Profile acad as default but when i close my autocad and then reopen the AutoCAD the default profile is going back to original AutoCAD.arg, but i already Set Current my setting.
In Desktop Shortcut Icon > Properties > Target, is hide.
is there any other options in need to set to make my setting as default?
Mike.Wohletz
right click on the icon shortcut on your desktop and select properties, you should see something like "c:\program files\Autodesk\AcadM\acad.exe". add to the end of it to look like this: "c:\program files\Autodesk\AcadM\acad.exe /p (your profile name"
the /p at the end is telling AutoCAD to use the profile listed, you dont need to have the .arg on the name..
This question should have been posted in the AutoCAD forum section for future reference.
Thanks for your help, but i tried still cannot, when i open the AutoCAD the default profile is original AutoCAD.arg.
Mind the quotation marks and try "c:\program files\Autodesk\AcadM\acad.exe" /p "your profile name"
btw rtfm
