Error plugin DTCP iproperties
Message 1 of 9
I've a win7, 64bit workstation with Inventor 2011 (activated) and Inventor 2012 as trail installed.
Inventor 2012 works fine but when I start Inventor 2011 and I call iProperties I'm getting an error:
Plugin not available or not properly installed.
Notify the system administrator that the installation is incomplete.
DTCP
I'm the local administrator on that workstation.
How can I solve this?
Geert
Replies (8)
Message 2 of 9
BrianRobbie2582
Community Visitor
Community Visitor
I have the exact same problem, but on only 1 out of 4 installs. So i would like the answer to this too.
Message 3 of 9
Have you tried an inventor 2011 repair?
It did the trick for me.
Message 4 of 9
Try to set UAC settings off. That was the solution for me!
Message 5 of 9
How do you do a repair ? I've tried by inserting the DVDs but it wants me to uninstall and re-install. I have the same problem with the iProperties being faulty; we're waiting for the IT guy to update our server for the Vault. I have to use 2011 in the meanwhile.
Thanx
Message 6 of 9
OK, I'm good, I found it. I was looking for something in Inventor help. It was in Windows "Add/Remove programs"
iProperties works fine now.
Boo-Yah !
Message 7 of 9
CAD-One
Correct me if I am wrong. To solve this iproperties error in 2011,
Go to windows control panel->add/remove program-> choose inventor-> repair
Is this the method?
Do we need inventor installation disks for this?
C1
win7
IV2011
C1
Inventor Professional 2020
Vault Professional 2020
AutoCAD 2020
Message 8 of 9
@CAD-One: that is precisely the method I used. I was afraid that Windows would try to uninstall everything, and was almost convinced I had to. When I saw I had the option to repair, I breathed a litle better. I had to feed the installation DVDs in order to complete the operation that took a whole 5 minutes. Rebooted computer just to be sure.
No problems since then. We are installing the 2012 Vault server monday morning. I can't wait to play with the new-fangled UI.
Hope this helps.
Message 9 of 9
CAD-One
Great. Thanks a lot.
We going 2012 next week. Can't wait to lay hands on.
C1
AutoCAD 2020
